nissan maxima (cefiro) 2001 A33 GV torque
Old Apr 25, 2013 | 02:04 AM
vip_usamamu's Avatar
hello evry one im glad to joine ur maxima fourms and sorry my english not very well
i has nissan maxima 2001 A33 or cefiro full option (GV) and i feel torque not good
my freind has aslo maixma 2000 same my car but (J) not full option only automatic gear box but this car when drive i feel torque is defrance fast respond and my car need to push more gas to run
so how to solve this i feel my car as normal no torque
my car its working good no problem with coil cuaz i change all 6 coil and tps change and adjust its stable car but only no torque maf also clean and working ok
Old Apr 25, 2013 | 03:50 AM
maxima_tyler's Avatar
any engine light on? if so find out what the codes are.
if no engine light, maybe it just needs a good tune. spark plugs, seafoam and an oil change.. its a 12 year old car so theres bound to be some carbon build up
Old Apr 25, 2013 | 04:06 AM
Hello thx for reply there is no any engine light on and evry thing normal
But i feel torqu not good plugs all new
Old Apr 25, 2013 | 05:25 AM
cjandura's Avatar
By torque are you refering to the power not getting to the wheels but the engine reving?
Old Apr 25, 2013 | 05:30 AM
it sounds like (to me) that everything is running smooth, but there is a lack of actual power. thats why im suggesting a good tune up and seafoam to clear out build up and whatnot.
with no codes, its hard to tell.
OP when you replaced the coils and MAF, were they with Nissan Genuine Parts? if they are aftermarket, perhaps even though they are working, they may not be working to oem standards...?
Old Apr 25, 2013 | 05:32 AM
cjandura's Avatar
Im betting transmission
Old Apr 25, 2013 | 05:57 AM
I change coil and plugs cauz befor when engin be hot car loss power and rpm go up and down its was 1 or two coil disconnect after hot
I think tune of engin defrant then other car but maybe lack of air i feel this aproblem but how i know where is luck
If u can suggest where i find this if u see any problem like this before
Old Apr 25, 2013 | 06:00 AM
cjandura's Avatar
Brother you need to take a video and post it of your problem because we are having problems understanding what you are trying to explain
Old Apr 26, 2013 | 11:50 PM
hello every one this my car i take photo for engine and video also for engine and there is one question this actual power only one pipe other car 2 pipe what is deference is this give car more torque ?
Old Apr 27, 2013 | 05:27 AM
coolsun's Avatar
Maybe you have bad catalytic converter/s? Those clog up and makes you lose alot of power. (i dont know if your country has them) If you do gut them out see if it makes a difference.
p.s. that brake fluid is very black.
Old Apr 27, 2013 | 05:35 AM
Thx alot but what is*catalytic converter ,?
Which part u mean
Old Apr 27, 2013 | 06:08 AM
coolsun's Avatar
Which part u mean
it has to do with the exhaust. It helps with air pollution, there might no be any pre catalytic converters on your car but im not sure until you look at it. There is one located in the front header/manifold and one in the back which is fat under the heat shield. I am sure you have a main catalytic converter towards the middle/rear of the car.
this is not always a cause of a power loss, but if the car has alot of miles on it, i would suggest gutting these if you have them.
the right side pic is the one with the cat, the left side is without.
Old Apr 27, 2013 | 07:11 AM
ah i understand u. this parts its for catback and connect to out smoke of the engine to send back side and give car more power but i dont know which part i has so i need to up my car when i wash and take aphoto and i will post here but one more question this actual power only one pipe other car 2 pipe what is deference . is this give car more torque ?
Old Apr 27, 2013 | 08:43 AM
coolsun's Avatar
the catalytic is so your car dont make dirty smoke out the exhaust, but can give you more power if you gut it out, not alot but alittle difference
Old Aug 7, 2013 | 09:47 AM
bad torque
still my car bad torque this video show how much my car so bad and lazy even there is no air filter and still bad
http://www.youtube.com/watch?v=syPui...ature=youtu.be
this road drive
http://www.youtube.com/watch?v=96ONm...ature=youtu.be
Old Aug 7, 2013 | 11:24 AM
NmexMAX's Avatar
dot dot dot ...
It's not a racecar. Looks fine to me. Seems as if maybe you're overreacting a tad? If you feel so inclined, check the VIAS cup. Also, removing an air filter isn't going to make that much if any of a difference.
Old Aug 7, 2013 | 12:49 PM
im taking about racing cuaz show much power car have i need only car fast respond i feel car lazy
do u think this device can solve my problem
http://www.carid.com/2001-nissan-max...-13547213.html
Old Aug 7, 2013 | 07:43 PM
coolsun's Avatar
im pretty sure that device will not work for the maxima.
maybe you have a dirty throttle body? start modifying the car?
Old Aug 8, 2013 | 07:29 AM
i read there is maxima coming 220 hp and 230 hp if my car 220 hp it will be this big defrant ?
i read also this ECU need to program or can change hp chip is this correct ? to increase power ?
Old Aug 8, 2013 | 08:58 AM
NmexMAX's Avatar
dot dot dot ...
I guess it is a little slow.
https://www.facebook.com/photo.php?v...3553730&type=3
Old Aug 8, 2013 | 05:20 PM
coolsun's Avatar
Im pretty sure it will not work at all. There isn't any real plug and play chip to increase power out there.
ah2002
Mar 9, 2016 01:42 PM
xUNIxPanther
Aug 27, 2015 10:09 PM
District
Aug 15, 2015 08:23 PM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
