5th Gen: What did you do to your 5th Gen today?
Old Dec 19, 2013 | 05:26 PM
  #441
SSJRICH's Avatar
Here ya go http://forums.maxima.org/general-max...-a33-sale.html
Just read it carefully and you see what is going on, and why it works. You will buy one after
Old Dec 19, 2013 | 05:33 PM
  #442
CauzinDrama's Avatar
I believe it's in the FSM. It involves getting the car in the air, loosening the bolt that goes thru the links between the axle and the body. Setting the wheels on ramps to load the suspension, and retightening the bolt. Obviously not the complete process of doing it, but really a general summary.
What happens is when you do a lower on the car, the rear axle actually will actually start sitting to one side. It gives the rear the look of one wheel looking like it is flush or even sticking out (usually the driver side), and the other side looks super tucked. The lowering pulls the rear out of spec, so it's just a matter of resetting it.
S
Because my car is not lowered and the rear axle is sitting about 15 millimeters to the left. I have a 15 millimeter spacer on the right wheel to make them appear the same right now.
Old Dec 19, 2013 | 05:38 PM
  #443
SSJRICH's Avatar
You just need a new link. The bushing in the link is probably worn out, hence the 15mm sag.
This is what you need http://www.autopartswarehouse.com/sh...an/maxima.html
Unless you are going to lower it, then buy the adjustable one.
Old Dec 19, 2013 | 05:56 PM
  #444
Na, no lowering here... Drive too much I the snow.. I'm going to look into the FSM for adjustments and get a closer look at the bushings. Thanks guys!
Old Dec 19, 2013 | 10:01 PM
  #445
clintb3astwood's Avatar
This
Old Dec 20, 2013 | 07:03 AM
  #446
DOODOOCHIP's Avatar
How's the light output from those projectors
Old Dec 20, 2013 | 09:58 AM
  #447
SSJRICH's Avatar
Nice work on the lights! Not quite my things, but if you custom installed the LEDS it looks good.
Old Dec 20, 2013 | 09:19 PM
  #448
Thank you sir! Its different but that's all that matters!
Old Dec 20, 2013 | 09:20 PM
  #449
Output is awesome, passenger side projector needs to be aimed a bit Lower
Old Dec 21, 2013 | 06:06 PM
  #450
Donkeypunch's Avatar
Replaced valve cover gaskets, intake manifold gaskets.
All the hard and cracking lines, hoses. New pcv valve.
cleaned throttle body and idle control valve.
Cleaned maf and used a 4'' coupler on the cold air snorkel instead of that
junk stock thing that always comes off.
Feels great Everything that wasn't supposed to be rock hard and cracking was,
and sludged up. lol
I just hope that was my oil leakage problem in the rear.
Old Dec 21, 2013 | 06:16 PM
  #451
hnamous's Avatar
Got a pretty good deal so I put in new NGK iridium ix plugs today. Less than $5/plug at advance. Didn't notice any real driving difference though. Old plugs were NGK R's. New MAF on the way too which I should receive on Mon. Hoping it'll correct this stalling issue at startup in cold temps. If not it'll be time for a new UIM gasket. No ses light so it feels like I'm chasing a ghost.
Maximase86: Very clean max man, it looks great with those rims
Old Dec 22, 2013 | 09:11 PM
  #452
mclasser's Avatar
Did a tranny D&F w/ Matic D and some Lube Guard Red, changed oil to Pennzoil Ultra w/ Purolator PureOne filter, used turkey baster to freshen up the PS fluid w/ some Dexron III I had laying around, and put in a bottle of Techron cleaner during the last fill up before the oil change. PU is some good oil and the VQ35 is SO quiet when I run it.
Old Dec 23, 2013 | 04:29 AM
  #453
95VQ30's Avatar
Rear brake pads & rotors, and bled my clutch correctly(had air in it from a master slave replacement). I also re-tightened my exhaust with hose clamps. fun stuff...
Old Dec 23, 2013 | 08:58 AM
  #454
King_Ten_Ahead's Avatar
Started installing a new head unit, replacing all 4 door speakers, and mounting a sub in the rear armrest.
Also replacing a sway bar end link
Old Dec 23, 2013 | 10:02 AM
  #455
Cabin air filter, Check!
Old Dec 23, 2013 | 04:40 PM
  #456
Rods03Max619's Avatar
Cleaned the Maf sensor...
Old Dec 23, 2013 | 05:59 PM
  #457
nestorlugo's Avatar
Size:  66.9 KB rear mount was totally separated from rubber(no fluid),front was in bad shape also...dropped the center beam and y-pipe project "X" is officially under way...
1.Timing Kit
2.Knock sensor
3.Oxygen sensors
4.Exhaust manifold gaskets
And lots of cleaning ...
Old Dec 23, 2013 | 06:08 PM
  #458
nestorlugo's Avatar
Size:  46.6 KB^^^rear mount
Old Dec 23, 2013 | 10:27 PM
  #459
nestorlugo's Avatar
Old Dec 24, 2013 | 09:02 AM
  #460
SSJRICH's Avatar
Wow bricks eh... that's old school... lol... That's a big project... Good luck.. Keep snapping those pics
Old Dec 24, 2013 | 12:51 PM
  #461
nestorlugo's Avatar
I will...thanks! Its been uneventful so far although seized pretty good all bolts on y pipe came out clean... will be taking next few days off !Merry Xmas .ORG!
Old Dec 24, 2013 | 02:34 PM
  #462
DOODOOCHIP's Avatar
finished painting a pair of tails that had been kicking around for a while.
Old Dec 25, 2013 | 12:29 PM
  #463
nestorlugo's Avatar
Size:  150.2 KB ok i lied I'm still at it....
Old Dec 25, 2013 | 03:02 PM
  #464
Tightened up the slack in my cruise control cable.
It always would be an abrupt on/off with the CC.
Thinking it was just another one of those "it's an old car, just the way things were"
But now after taking out the slack it holds a steady smooth MPH.
I use it allot now.
Old Dec 25, 2013 | 03:52 PM
  #465
TriniSpeC's Avatar
maxima business
Old Dec 25, 2013 | 05:07 PM
  #466
why is it a 11.8 at idle?
Old Dec 25, 2013 | 06:11 PM
  #467
TriniSpeC's Avatar
Long story short my cai goes behind the bumper and when the filter gets dirty it causes the car to run a bit rich.
Normal idle I bounce around at 14.5-14.7 look at the start of the video.
Old Dec 26, 2013 | 04:48 PM
  #468
ramriv777's Avatar
4 new tires (Michelin Pilot Sport A/S 3), balance, and alignment. Couldn't wait to get rid of the crappy, noisy Firestones I bought her with.
Sent from my iPhone using MaximaOrg
Old Dec 28, 2013 | 01:10 PM
  #469
YGG's Avatar
YGG
Couple days ago now but I ordered OBX headers and an ISIS 240SX 3" test pipe. BRM 3" exhaust to follow in the next couple weeks, then when I get my tax return tuning and suspension will commence.
Old Dec 30, 2013 | 03:23 PM
  #470
barristan's Avatar
Where did you find the OBX headers? I was told they weren't available anywhere until at least February.
Old Dec 30, 2013 | 04:57 PM
  #471
IceBerg's Avatar
Does anyone know if the 01 mudflaps are the same As an 02 courtesy only shows 2000-2001
Old Dec 30, 2013 | 05:45 PM
  #472
Chris Gregg's Avatar
Get Off My Lawn
Rear end bumpers are the same. Rear mudflaps are interchangeable. As long as its not an anniversary edition.
Old Dec 30, 2013 | 05:46 PM
  #473
Get Off My Lawn
Very nice.
Old Dec 30, 2013 | 06:12 PM
  #474
IceBerg's Avatar
Thanks how about the front flaps ?
Old Jan 1, 2014 | 03:42 PM
  #475
TriniSpeC's Avatar
happy new years
Old Jan 1, 2014 | 09:15 PM
  #476
DjHackStyle's Avatar
Sparco globe x shift **** with reverse lockout
Old Jan 3, 2014 | 03:26 PM
  #477
nestorlugo's Avatar
Size:  76.4 KB ok so after the weather has been stationed around mid 40's to low 30's around the metroplex(DFW) "project X" hit a major snag.
Scrapped no.1 on the list, all other objectives were completed shipping around the holiday sucked...i just received the lca yesterday at 6pm when ordered was made on 28th...so six days ups ground from Dallas to Arlington...well....other than that the only non issue i had was the trans mount(buy the aluminum one,save the hassle)needed 3/4 of an inch spacer on the bolts since the new mount was not as beefy. .
Tomorrow it should be buttoned up and ready to fire...However i did strip the two rear mounting bolts on the driver lca...i was able (with a lot of hevos)to screw them all the way in ....well i guess i can get a sub frame from a donor in February when i plan to drop the vq and overhaul.timing and piston rings,comp cams..Barrett Jackson here i come....
Old Jan 3, 2014 | 04:19 PM
  #478
nestorlugo's Avatar
Size:  98.2 KB bank2 leak went oem on the gasket worth the extra money (18sumn mi.)I'll take that!
Bank1 was clean besides the permanent oil residue from past valve cover leaks but nothing around manifold beside a small amount of rust on shield screws...backed out of the replacement on it when i realized that there's no way to torque the four bolts on the engine mount bracket without removing the engine
Old Jan 3, 2014 | 04:35 PM
  #479
nestorlugo's Avatar
Size:  66.5 KB started on the first two then quickly put them back
Old Jan 3, 2014 | 04:43 PM
  #480
nestorlugo's Avatar
Size:  39.3 KB previous owner had replaced power steering hp hose, after some wipe down nothing on the bolt but a leak remained on the return hose sniped an inch of this end and changed clamp to worm style clamp ...we'll see!
