5th Gen: What did you do to your 5th Gen today?
Old Jun 28, 2016 | 07:03 PM
  #2641
HerBlue2kSE's Avatar
Front suspension completely rebuilt including converting to the ES man trans mounts. Turned the car around in the garage and will replace the rear struts as time allows. Also ordered new tires for the factory 16" SE/GLE 5 spokes I picked up. Once the struts are done it will go in for a 4 wheel alignment.
Old Jun 28, 2016 | 08:29 PM
  #2642
nestorlugo's Avatar
Theoretically the rear is not adjustable !
Old Jun 28, 2016 | 08:43 PM
  #2643
OK... so the front will get aligned.
Old Jun 28, 2016 | 08:53 PM
  #2644
nestorlugo's Avatar
Ps: don't let them charge you extra oh and don't believe them if they say you need camber bolts
Old Jun 28, 2016 | 09:00 PM
  #2645
Child_uv_KoRn's Avatar
Bad *** Newb
Werd. I tell them I'm paying for 2 wheels only. If they get pissy, move on.
Old Jun 29, 2016 | 06:16 AM
  #2646
ManualMaxima's Avatar
5th Gen till she dies!
Went to a "U Pull It" type salvage yard again after getting a pristine OEM HP steering hose a few weeks ago for $6.50. There are probably 10-12 5th gen Max's in the yard. This time I grabbed 2 MAF sensors, rear leather seat, 2 front leather seats, 2 coils, and a boat load of various little parts for $79. One of the junkyard seats was damaged on the seatback only, so I replaced that part of it with the back of my original passenger seat. With all that I did, the interior looks very close to brand new. I wanted to grab a i30 electric rear window shade I saw, but decided against it...
Old Jun 29, 2016 | 05:03 PM
  #2647
mrjamaica98mx's Avatar
Finally
Old Jun 29, 2016 | 05:06 PM
  #2648
nestorlugo's Avatar
One word !!!! look see this guy knows ^^^^^
But I should ask,by any chance is there a 5 gen with a tan carpet in good shape?
Old Jun 29, 2016 | 05:08 PM
  #2649
Mech changed outer tie rod end from research i know i need alignment but i'm noticing steering wheel seems to turn almost 360 on turns.
Old Jun 29, 2016 | 06:00 PM
  #2650
One word !!!! look see this guy knows ^^^^^ : But I should ask,by any chance is there a 5 gen with a tan carpet in good shape?
Most of these cars have greasy parts strewn all over the insides that others have pulled from the car. There was an I30 with tan carpet that was good though if I remember. This is in Atlanta though.
Old Jun 29, 2016 | 07:58 PM
  #2651
Finished the complete suspension rebuild tonight by doing the rear struts. New tires and front end alignment done on Friday. I cannot wait to take it for a spin after all the work is done.
Old Jun 30, 2016 | 12:04 PM
  #2652
Installed the glovebox and passenger a pillar cover from a car at the local pick-n-pull. Working on the wiring to get the compass/auto dim mirror installed.
Old Jun 30, 2016 | 12:29 PM
  #2653
Itz Shak's Avatar
Changed the oil, cleaned throttle body, cleaned maf, and the pop charger cone filter.
Old Jul 2, 2016 | 05:56 AM
  #2654
Ordered front wheel bearings. I guess at 127k miles it is time to do them.
Old Jul 5, 2016 | 08:24 AM
  #2655
Replace the broken driver's rearview mirror with one from the local yard in the same color as my car. Also added the autodial/compass rearview mirror. Also working on replacing front wheel bearings.
Old Jul 5, 2016 | 12:44 PM
  #2656
rvamax's Avatar
Finally got to the front brakes. Brembo blanks and hsp pads, they're pretty nice, no more shaking under breaking although they grown a little during cold slow stops. Also used a clay bar on the paint, what a difference.
Old Jul 8, 2016 | 06:25 PM
  #2657
nestorlugo's Avatar
Shed a few lbs from the vq with this thing!
Royal pain finding the correct belt since the one suggested on the site was too short!!!
Right belt pn k060410
Old Jul 8, 2016 | 07:02 PM
  #2658
Itz Shak's Avatar
Nice is that the same ralco rz? I did mines last month, definitely worth it. It's atleast two times lighter than oem
Old Jul 8, 2016 | 07:06 PM
  #2659
nestorlugo's Avatar
This is a knock off of the unorthodox
Do you remember the pn of the belt you used?
Old Jul 8, 2016 | 07:15 PM
  #2660
Itz Shak's Avatar
Lol, 5060431 for a/c and idler belt. 5040305 for the power steering belt
Old Jul 8, 2016 | 07:22 PM
  #2661
nestorlugo's Avatar
Oh OK that's probably cause you have a 3.5
Old Jul 8, 2016 | 07:40 PM
  #2662
cornholio's Avatar
are you not 3.5 swapped? for some reason i thought maybe you made that jump
if not, give me more info on dat pulley. was planning to pull mine on the next oil change and do the seal behind it, i had thoughts to replace the pulley while i was there
Old Jul 8, 2016 | 08:02 PM
  #2663
nestorlugo's Avatar
No I chickend out in the last minute! Still 3.0 strong
Got the pulley from ebay for da fitty! Just put some thread lock on the timing ring as suggested by a fellow member!
Put on a 1/2 extention on the crank bolt I used the floor for leverage some use the oil filter than just bump the starter, my pulley was stuck pretty good but just sprayed it and tapped it with a sledge hammer and was able to wiggle it out!
Old Jul 9, 2016 | 11:43 AM
  #2664
Finally got the wheel bearings pressed in and all the front end parts reinstalled. Also installed Knight's right and left engine/trans mounts.
Installed a Kenwood Exelon DPX791BH headunit but I am waiting for stuff to complete the wiring with the Bose system.
Old Jul 9, 2016 | 11:59 PM
  #2665
Itz Shak's Avatar
Raced a stock 2011 Maxima. Friendly race
Old Jul 10, 2016 | 04:21 AM
  #2666
losifanatic's Avatar
5th gen vs 7th gen Maxima - YouTube
Nice! I was goofing off with a guy up the road from me. He has a bmw 335i 2 door. Raced him from about 45 to 120mph. I pulled 1/2 a car on him. No to bad being that car runs a 13.5 in the 1/4.
Also picked up a pioneer 3800bhs and installed it. My less than 1 year old pioneer 2700bs died on me. Hope the 3800 lasts longer (bought it from a dealer this time so I have a warranty just in case)
Old Jul 10, 2016 | 11:01 AM
  #2667
96SEmaxB's Avatar
Replaced back brakes, one bad caliper, after fighting with left rear caliper piston for an hour...love it
Attached Thumbnails 5th Gen: What did you do to your 5th Gen today?-img-20160710-wa0003.jpeg
Old Jul 11, 2016 | 06:27 AM
  #2668
marky3320's Avatar
Replaced the transmission speed sensor yesterday. Hopefully the transmission won't act up again for awhile.
Old Jul 11, 2016 | 07:27 PM
  #2669
Itz Shak's Avatar
So my car ran out of gas today @ half tank, so I had to use that old faithful gas can in the trunk.
I have the p0455/p1448 code but I was told that these wouldn't cause our gas needles to read wrong. (Which makes sense)
Could it be the Fuel pump or sending unit? I saw in a thread that our cars fuel pumps and sending units don't usually go bad. When it did run out of gas, I heard a popping sound from under the hood. Almost like a leak.
Any help is appreciated, as I'm Kinda stumped..
Old Jul 11, 2016 | 07:40 PM
  #2670
Itz Shak's Avatar
I'm leaning towards the sending unit
Old Jul 12, 2016 | 02:29 AM
  #2671
I replaced my pump and sending unit and my needle still reads wrong. Did the gauge cluster test and yup the gas needle was off a bit.
Old Jul 12, 2016 | 03:28 PM
  #2672
VQ35maxima=Beast's Avatar
Feel a big difference is revving?
Old Jul 12, 2016 | 07:51 PM
  #2673
2damax's Avatar
[QUOTE=Itz Shak;9118024]So my car ran out of gas today @ half tank, so I had to use that old faithful gas can in the trunk.
http://boredmder.com/FSMs/Nissan/Maxima/2002/EL.pdf
See page 122. Good place to start.
Old Jul 12, 2016 | 09:19 PM
  #2674
Itz Shak's Avatar
[QUOTE=2damax;9118189]
Indeed it was. I just adjusted my gas needle as 2kmaxim suggested. In this thread https://maxima.org/forums/5th-genera...l-problem.html (post #33) I got it to read just like the FSM. So we'll see if that fixes the problem, otherwise fuel sender unit it is.
Old Jul 13, 2016 | 03:29 PM
  #2675
nestorlugo's Avatar
Tbh, I think is all in my head but feels like it can pick up faster at higher speeds when before throttle response was a bit lagging before the car actually went
Old Jul 13, 2016 | 06:03 PM
  #2676
Itz Shak's Avatar
Seems like everyone's cluster is off by a bit though..
Old Jul 13, 2016 | 07:45 PM
  #2677
Wired up the 5.5 factory headlights and will finish the install tomorrow.
Old Jul 13, 2016 | 08:52 PM
  #2678
Itz Shak's Avatar
I'd love to hear your input on this gas dilemma korn
Old Jul 13, 2016 | 09:50 PM
  #2679
Donkeypunch's Avatar
Does the needle move when the a/c is turned on?
If so that could be a poor ground. My bmw did that that's why i'm saying it could be it.
Just add more ground straps if it does.
Old Jul 15, 2016 | 01:57 PM
  #2680
Itz Shak's Avatar
So I went to a junkyard today to swap out clusters.. I plug in the one from the junkyard and it was worse than my original.
It's stuck @ Full tank and has 228k miles on it.
They don't do refunds on electrical parts, so they're going to find me another one by Monday.
