5th Gen: What did you do to your 5th Gen today?
Old Oct 24, 2016 | 07:01 AM
  #2801
Canadianmaxownr's Avatar
Originally Posted by cornholio
my legs are not long enough to be able to press the brake pedal and take a selfie with the back of the car, unfortunately
Try with a Block or a stick or something like that! i know you can!
Old Oct 24, 2016 | 08:51 AM
  #2802
maximatech12's Avatar
This sucks if your tail light stopper breaks off on your brake pedal assembly and you can't see the tail lights left on. Battery drains.
take out the stopper take a picture then replace the stopper. It's probably going to break anyway.
Old Oct 31, 2016 | 08:13 AM
  #2803
MadMax SE's Avatar
80A liquid urethane fun!
I must of fudged up my 3m trans and pass mounts because my motor rocks like hell. I ended up buying energy suspensions 80a high performance liquid urethane and doing them over. I ordered black and it came in red :/
Urethane goodness
Old Oct 31, 2016 | 09:42 AM
  #2804
Donkeypunch's Avatar
Why didn't u just get the press in mounts?
Old Oct 31, 2016 | 04:47 PM
  #2805
MadMax SE's Avatar
I don't believe es makes press in trans and pass mount bushings, I've looked everywhere. I already have the press in front and rear torque mount's.
Old Oct 31, 2016 | 08:37 PM
  #2806
Oh, I see.
Old Nov 1, 2016 | 07:35 PM
  #2807
maximized98's Avatar
Addicted to the Org
My brand new Cattman 3" exhaust has arrived
Old Nov 9, 2016 | 11:52 AM
  #2808
Originally Posted by maximatech12
broke the tab on the quick release in the fuel pump container.
It still snaps in place though and now I have a new Filter in. What to do about the broken tab on the return line quick conntect?
Can I cut the whole return line out and use universal rubber tube or will it burn up from heat?
Just realized I can replace the quick connect tab. They are able to remove replaceable. They were so old they turned brown from years of fuel fumes.
Old Nov 9, 2016 | 11:57 AM
  #2809
You replace rubber mounts too?
Old Nov 9, 2016 | 04:03 PM
  #2810
SquidBeak's Avatar
that sure am purdy!
Old Nov 9, 2016 | 04:42 PM
  #2811
Child_uv_KoRn's Avatar
Bad *** Newb
Originally Posted by SquidBeak
that sure am purdy!
But will it hang correctly :|
Old Nov 9, 2016 | 04:44 PM
  #2812
SquidBeak's Avatar
Really?
Ouch...
Old Nov 9, 2016 | 04:51 PM
  #2813
Bad *** Newb
Really?
Ouch...
Mine doesn't. I've read that others have been less than pleased with some of theirs. 2.5" was always perfect.
Old Nov 10, 2016 | 05:28 AM
  #2814
Addicted to the Org
I got lucky
Old Nov 10, 2016 | 06:59 PM
  #2815
I had a service soon light and it was code 720.
There's no shifting troubles so idk why it's throwing that code.
Anyone else have a 720?
Old Nov 19, 2016 | 10:59 PM
  #2816
Reallyslowrio's Avatar
Installed the 5pc NWP spacer kit along with new plugs and coils. The car starts quicker and has never pulled so hard through the gears.
1st gear is almost completely useless now as all it does is roast the tires down, but I'm ok with that.
Old Nov 20, 2016 | 06:53 AM
  #2817
losifanatic's Avatar
Yup know all about that. Even with a 7150rpm limit l still do nothing but burn them in first. Awesome isnt it!!!!!
Old Nov 20, 2016 | 04:38 PM
  #2818
Love it.
I'm actually talking to Murphys_law right now about getting a flash tune.
Old Nov 20, 2016 | 04:49 PM
  #2819
mclasser's Avatar
Rotated the tires like a straight OG
Old Nov 20, 2016 | 05:47 PM
  #2820
cornholio's Avatar
washed and waxed this weekend
Old Nov 20, 2016 | 05:53 PM
  #2821
cornholio's Avatar
in person it looks a little better, but i probably just suck at detailing (and/or taking pictures)
before
after
Old Nov 20, 2016 | 06:05 PM
  #2822
Bad *** Newb
4x4 alert :P
Old Nov 20, 2016 | 08:28 PM
  #2823
cornholio's Avatar
4x4 alert :P
Yeah, it's kinda on the list. Too lazy to research if I should go spring/strut or coilover to solve it. Also too lazy to convince the wife it's worth the money. I'll probably do what I usually do and tell her it cost half what it actually did
Old Nov 20, 2016 | 09:05 PM
  #2824
Bad *** Newb
Now, that's a smart man
Old Nov 21, 2016 | 12:42 PM
  #2825
TSelanne's Avatar
Finally finished cattman headers and ypipe install along with ES motor mounts. Not really a "what did you do today" but more like "what did you do over the last six weeks" lol.....could only work a few hours here & there on weekends, plus it was my first time so I was going SO slow......tough to find time between work, family, etc. And I pretty much had to do the job 3 times trying to get the ypipe not to hit the crossmember. But it's done, yay!
Old Nov 27, 2016 | 02:57 PM
  #2826
PopularWithVertigo's Avatar
Oil lamp has been flickering lately, along with a ticking and puttering and some trouble codes (0011, 0021, 0031, 0051). Did some in depth research, put on my tinfoil hat and started drawing wildly uninformed connections between these culprit systems (A/F sensors and intake valves) and came up with this conspiracy theory that I have an oil pressure problem fouling everything up. So I researched causes of oil pressure problems and came to the conclusion that I need an oil pressure switch!
"Eureka! I've solved it," I bellowed at my cat. I jacked the beast up, got on my back and went in blind with the ten dollar replacement part in one hand and a 27mm socket in the other... I smoothly installed the thing with no hiccups. Never had such an easy time...
Took it for a test drive. No change in symptoms.
Old Nov 27, 2016 | 03:06 PM
  #2827
That was going so great
Old Nov 27, 2016 | 03:12 PM
  #2828
I know. I was so pleased with how things were going that I wasn't even that upset about the outcome. Gonna try a bottle of some engine treatment next and see if its just a sludge problem. Here's hoping.
Old Nov 27, 2016 | 05:20 PM
  #2829
Bad *** Newb
I'd be way too paranoid and have to pull the lower oil pan. There have been crazy things found in there...like paper towels. There's three possibilities for the oil light flashing. The sender is bad/clogged, pick up is blocked or oil pump is bad. It's highly unlikely to be the pump. Checking the pick up and running some detergent in the oil would be my actions. You replaced it, so that's not so good news. Pick up must be checked.
Given the codes and light you are absolutely dangerously low on oil pressure. I wouldn't drive it at all. Check for glitter in the oil/pan when you drain it.
Old Nov 27, 2016 | 05:46 PM
  #2830
I dumped in a bottle of Rislone Engine Treatment. Smooth as a top. The changes were immediate. The oil light flickered once or twice more and stopped, the noises are gone. I'm kinda dumbfounded by how easy that was.
This problem has popped up in the past, always about a month before the next scheduled oil change: flickering light, same trouble codes, distinct puttering/ticking sound... usually goes away with an oil change but I decided to play around with it this time and try to verify what exactly is happening. I'm gonna open up the pan and take a look at it. Its gotta be some kind of blockage or fouling.
Old Nov 27, 2016 | 06:16 PM
  #2831
Bad *** Newb
And you're sure the oil isn't low lol
Old Nov 28, 2016 | 10:59 AM
  #2832
Replaced the lower control arms and sway bar end links yesterday. Ended up cutting the end links out after stripping them and having to torch out the control arm mount. Good times.
Got it all back together and took it around the block only to discover that I must have ****ed up my driver CV while working on it. Super.
In other news, shipped out my ecu to Murphys_law today to be tuned.
Old Nov 28, 2016 | 11:13 AM
  #2833
You're really going to like it. Makes a huge difference
Old Nov 29, 2016 | 09:47 AM
  #2834
I have a question you for you guys.
If I get the poly motor mounts will that stop my tranny and side mount from breaking?
Because there are my second ebay set all around and they keep breaking.
Will this happen again with poly motor mounts? I know it's going to be harsh but whatever.
Old Nov 29, 2016 | 09:52 AM
  #2835
Just dont go with ebay one... i got the original one in it, passed something like 14 winters and summers and the still in mint condition..
Old Nov 29, 2016 | 06:55 PM
  #2836
lucky you must baby it real good.
Old Nov 29, 2016 | 06:58 PM
  #2837
Not at all hahaha!
Old Dec 11, 2016 | 04:01 PM
  #2838
Cleaned her inside and out today. Also swapped the fuel lever sensor from my daughters car to mine to see if that was the issue for the fuel needle not reading right. Well that wasn't it so l swapped the instrument clusters. Yup that did it. So apparently my cluster is bad.
There is a guy on ebay that does instrument cluster repair for the 5th gen maxima. Anyone used this guy before?
http://m.ebay.com/itm/2002-2003-2004-NISSAN-MAXIMA-instrument-Cluster-Repair-Speedometer-Repair-/171979577659?nav=WATCHING_ACTIVE
Old Dec 11, 2016 | 07:56 PM
  #2839
mclasser's Avatar
Did an oil change with M1 HM 5W30 & M1 filter, changed air filter (FRAM) and finally re-aimed the headlights. No more staring at the ground 6 ft in front of me!
Old Dec 12, 2016 | 09:15 AM
  #2840
TSelanne's Avatar
Installed wraith passenger & tranny poly mounts. Now that all 4 are poly it actually vibrates less than when I only had the 2 ES mounts.
Put on the snow shoes (just in time for the 8" we got over the weekend).
Oil change & filter.
Replaced fog bulbs and side blinker bulbs.
Changed out the floor mats.
