5th Gen: What did you do to your 5th Gen today?
Old Mar 22, 2017 | 12:19 AM
  #2881
Itz Shak's Avatar
Originally Posted by mydecember1985
I think your tranny cooler is too little, too late. Have you tried the lucas slip fix fluid?
Yeah that's coming up, going to change the fluid once more with valvoline maxlife atf along with the lucas and see if anything changes.
Old Mar 22, 2017 | 05:28 PM
  #2882
mydecember1985's Avatar
with that Transgo in there, you're definitely gonna want that cooler in ASAP. Look around and see if anyone says 2 bottles of the Lucas fix fluid is too much.
Old Mar 23, 2017 | 07:56 PM
  #2883
Itz Shak's Avatar
I only did one bottle but the symptoms are still there. Now when I wot it, it stays at redline without shifting.. (left it there for about two seconds). Time for a new transmission.
Old Apr 4, 2017 | 12:12 PM
  #2884
VQ35maxima=Beast's Avatar
new exhaust gaskets to go around, replaced knock sensor as well as replaced intake gaskets and valve cover gasket. with a nice oil change on the 2000.
Old Apr 4, 2017 | 08:01 PM
  #2885
Robert Baker's Avatar
I installed the drivers side cv shaft seal (OEM) and the passengers side too.
Old Apr 6, 2017 | 11:06 AM
  #2886
tech2000's Avatar
Finally lowered my car here are some before and after pics.
Before
After
Old Apr 6, 2017 | 08:00 PM
  #2887
cornholio's Avatar
Before
After
looks good, what spring/strut combo or coils did you go with?
Old Apr 6, 2017 | 11:49 PM
  #2888
tech2000's Avatar
Thanks It's Tein Lowering springs with tokico shocks
Old Apr 7, 2017 | 10:21 AM
  #2889
How is the ride from a stock standpoint? Were they Tokio blues or Illuminas?
Old Apr 7, 2017 | 11:34 AM
  #2890
tech2000's Avatar
They are Tokico Hp Blues they ride even better than stock to be honest with you. I have put Monroe quick struts and Kyb gr-2 on my car and the tokico blues are way more comfortable than both of them.
Old Apr 8, 2017 | 10:25 AM
  #2891
Itz Shak's Avatar
Clean! I might have to look into that setup myself.
Old Apr 11, 2017 | 10:14 AM
  #2892
I installed the Transmission solenoids I bought (USED OEM 65k) onto the valve body. Then cleaned them up and installed the valve body into the transmission.Next, I installed the transmission filter and torqued it all down. Installed the transmission pan and gasket.
Old Apr 16, 2017 | 03:45 PM
  #2893
cgilley's Avatar
Replaced the remainder of ignition coils today - girl is zipping along much better.
Old Apr 20, 2017 | 09:50 AM
  #2894
wellshii19's Avatar
Past week I replaced the gear oil, fuel filter,cabin filter,hood struts and air filter.
Car needs struts and shocks,but that's later.
Old Apr 20, 2017 | 03:29 PM
  #2895
Donkeypunch's Avatar
I did this a while ago but if anyone is getting like a vibration/groaning when you turn the wheel almost completely locked it's a leak in the power steering hose.
It's been doing that for years but now that the leak got big replacing the hose fixed it.
Something would vibrate like a ***** ****a when fully locked.
Old Apr 24, 2017 | 10:27 PM
  #2896
Maximurder's Avatar
Installed a short ram intake
It went well, many gains
Old Apr 25, 2017 | 12:01 PM
  #2897
SquidBeak's Avatar
what intake did you install?
Old Apr 25, 2017 | 02:50 PM
  #2898
Child_uv_KoRn's Avatar
Bad *** Newb
fast and furious injen
Old Apr 25, 2017 | 06:51 PM
  #2899
SquidBeak's Avatar
Which Fast & Furious? 1, 2, 3, 4, 5, 6, 7 or 8?
Old Apr 25, 2017 | 07:17 PM
  #2900
hell yeah bro fk that 4 banger you got em!!
Whats ur car domain dowg?
Old Apr 27, 2017 | 07:00 AM
  #2901
jackman's Avatar
The SES light came on a couple weeks ago, the code was P0155 (O2 Sensor Heater Circuit Malfunction Bank 2 Sensor 1). I tested the sensor at the plug using an ohmmeter, and the heater element was open. After replacing the sensor last weekend, it's like a whole new car! Cold-engine surging/hesitation is gone, and gas mileage has increased big time. It's had those symptoms going back at least six months, so I think some other part of the sensor must have failed way before the heater. Finally... something easy to fix!
Old May 1, 2017 | 03:41 PM
  #2902
mclasser's Avatar
Had some time this weekend so I got the car ready for the summer.
- Oil change w/ MaxLife 10w40 & M1 filter
- ATF drain & fill w/ MaxLife & Lubegard Red
- Coolant D&F w/Peak Long Life
- Polished up oxidized fog lights
Old May 1, 2017 | 04:00 PM
  #2903
maximatech12's Avatar
Why not just use the matic-D they suggest?
Old May 2, 2017 | 03:08 PM
  #2904
Bad *** Newb
Fast and Furious with Tom Sawyer: Injen Joe (I know, not same spelling)
I mean, it's only a matter of time with enough sequels. It'll be like an infinite multiverse. Anything is possible.
Old May 2, 2017 | 03:48 PM
  #2905
SquidBeak's Avatar
Good one.
When I heard that the last F&F earned $100M on it's debut, I took up permanent residence in my underground bunker. Surely the end is VERY near.
Old May 7, 2017 | 06:02 PM
  #2906
5thgendriver's Avatar
added a set of 6gen wheels I found cheap. also touched up my calipers.
Attached Thumbnails 5th Gen: What did you do to your 5th Gen today?-20170430_163710.jpg   5th Gen: What did you do to your 5th Gen today?-20170430_171253.jpg   5th Gen: What did you do to your 5th Gen today?-20170502_200243.jpg
Old May 7, 2017 | 10:38 PM
  #2907
SquidBeak's Avatar
Damn, those look great. Wow.
Old May 8, 2017 | 07:46 AM
  #2908
SubwayVQ's Avatar
What paint is that? Did you paint them yourself?
Old May 8, 2017 | 08:24 AM
  #2909
thanks
wheels are powder coated and I used dupli-color caliper paint on the calipers.
Old May 14, 2017 | 03:23 PM
  #2910
BC BR Coilovers
I finally got around to installing my new suspension.
Looks about right to me.
So pretty.
I wonder what size rim I can fit in there now!?
Old May 15, 2017 | 07:54 AM
  #2911
flames101sully's Avatar
Looks good
Old May 15, 2017 | 01:46 PM
  #2912
Domf3's Avatar
I replaced all 6 ignition coils and spark plugs. Good to go for another 100k miles.
Old May 15, 2017 | 05:27 PM
  #2913
So pretty.
nice...you done good
Old May 20, 2017 | 06:54 AM
  #2914
Drilled out three stripped out Exhaust Manifold stud holes tapped new threads then inserts.
I went for the whole m10x1.25 repair deal.
Two turned out great but one didn't seat that great. I guess I could've went a bit deeper with the tap before installing the insert.
I also used a tap guide that I also use for the drilling. This made things perfect for getting the stud angle right.
Old May 22, 2017 | 01:34 PM
  #2915
Sold my 2000, still have the 2002, but picked up a 09 G37s
Old May 22, 2017 | 03:39 PM
  #2916
sanford7575's Avatar
Installed Powerstop Z26 Rear Brakes, Rotors, and Calipers on my '02 GLE. Loving the red calipers as an accent to the black body! Thinking about getting a kit for the front next!
Next week I'm on doing a major overhaul for inspection with new control arms, tie rods (inner & outer), End Links, and my 5th CV Axle replacement (@$#!%$^! Nissan Advantage Axles), they suck!
Old May 22, 2017 | 04:03 PM
  #2917
pics or it ain't so...
Old May 29, 2017 | 11:29 AM
  #2918
Originally Posted by maximatech12
Replaced the fuel return hose from the regulator with 5/16 universal fuel hose Mad in the USA by Armormark. I guess it was 7mm now it's 7.9mm.
I just realized the replacement return hose is just fuel line.J30R7
Supposedly I needed fuel injection hose which has a higher rates psi range.J30R9 CARB compliant
This I'll have to replace.
I'm seeing stainless steel braided fuel line for sale on eBay.
5/16" 8MM STAINLESS STEEL BRAIDED PTFE Teflon FUEL HOSE LINE OIL ETHANOL 10FT | eBay
http://m.ebay.com/itm/5-16-8MM-STAIN...%257Ciid%253A8
try that for return line? It's listed as teflon
Old Jun 3, 2017 | 08:04 AM
  #2919
So I think all the smaller hoses are 1/4" on this car? Throttle coolant hose, return fuel hose, transmission oil cooler hose?
I had 5/16" which may be a bit bigger?
Anyway another "special" order!
3/8" double sided molding(moulding) tape for the wheel well molding(moulding) I removed for the new radiator support.
2000's Nissan bumper molding
Old Aug 26, 2017 | 04:20 PM
  #2920
losifanatic's Avatar
Changed the clutch release bearing and rear brakes today.
It's no fun for a 140lb guy to drop and reinstall the transmission while the car is on Jack stands by your self.
