loosing Brake Fluid no visable leaks
Old May 6, 2013 | 12:27 PM
TravisCadello's Avatar
Lifted car with forklift n traced every last brake line and nooo damn leaks!!! bought car 6months ago seen it was low filled it then 3months later n 2800miles later i see it low again only half reservior figured I'm just eating pads low. well this morning i completely lost my pedal and i can't find where its going so frustrating.
01 5spd ABS System equipted.
Old May 6, 2013 | 12:35 PM
MrEous's Avatar
^ Jeff™
Might be an internal leak...
Old May 6, 2013 | 01:22 PM
I don't see how that would be lol..My friend said its burning it i laughed my *** of.
Old May 6, 2013 | 01:25 PM
cjandura's Avatar
Aint it hooked to the hydrolic clutch system also?if it is check to see if your clutch is soaked
Old May 6, 2013 | 01:39 PM
I don't think it is cause i checked clutch reservoir n she's full.
Old May 6, 2013 | 04:32 PM
MrEous's Avatar
^ Jeff™
Oh, lol, it is possible for a master cylinder to leak internally.
Old May 6, 2013 | 04:44 PM
chrome91's Avatar
check your brake booster, theres a thin diaphragm plate in it. if it goes bad, it can allow brake fluid to collect in the booster
Old May 6, 2013 | 07:45 PM
DjHackStyle's Avatar
Ive heard the master cylinder leaks into the brake booster. Remove the brake master cylinder and check behind it if its soaked in brake fluid, probably all over the inside of the brake booster
Old May 7, 2013 | 07:49 AM
NmexMAX's Avatar
dot dot dot ...
Got the same issue on my 4th gen, weird.
Old May 7, 2013 | 08:02 AM
Found That Sucker lol. bad Booster Thanks Guys. This Gon Be A Fun Job. Few Beers n busted Knuckles commin.
Old May 7, 2013 | 04:39 PM
chrome91's Avatar
called it
Old May 8, 2013 | 01:30 PM
Gemner's Avatar
the clutch uses brake fluid, but the systems are entirely independent of each other
Old May 8, 2013 | 04:30 PM
chrome91's Avatar
yep clutch has its own master cylinder, its system uses brake fluid like Gemner said
Old Jun 21, 2013 | 01:29 PM
Hagii73's Avatar
question, if the fluid is leaking into the booster, do you have to replace both the master and the booster or just the booster?
Old Jun 21, 2013 | 01:46 PM
Gemner's Avatar
I dont know, but I can speculate. Unless this is an unusual master/booster setup, the booster would not have any brake fluid in it and shouldnt be affected by an M/C leak. the booster is basically just a vacuum diaphragm that makes pushing the brake easier. If the fluid is leaking into the booster you need to replace the m/c but maybe not the booster
Old Jun 21, 2013 | 01:49 PM
Hagii73's Avatar
that would be nice since the booster is 3x the cost of the master. Ill be taking them off this weekend to look at em. thanks for the thoughts
Old Jun 21, 2013 | 01:55 PM
rebelhell's Avatar
IMHO, I'd replace both. There shouldn't be brake fluid inside the brake booster and I can't imagine it does nice things to the diaphragm. But I'm no expert...I replace extra parts sometimes just because I want to make sure I only have to do a job once.
Old Jun 21, 2013 | 02:44 PM
chrome91's Avatar
i know on old school cars you can replace just the diaphragm, not sure about newer ones. but especially Nissan brake boosters and master cylinders are cheap as ballz. just replace both for safety sake
Mar 12, 2020 12:06 AM
captchaos
Mar 15, 2016 12:18 PM
The Wizard
24
Oct 1, 2015 08:47 PM
bbsitum
Sep 11, 2015 04:55 PM
ag90fox
Sep 9, 2015 12:22 PM
