VSS Wire 03 maxima Pioneer's AVIC-X940B
Old May 12, 2013 | 11:39 AM
zakevans21's Avatar
Installing Pioneer's AVIC-X940B and dont know where to locate the Vss wire. I heard you can find it behind the cluster. how do you remove the cluster?
Old May 12, 2013 | 05:13 PM
cjandura's Avatar
Oh boy! If you can put a radio in you should be able to pull the cluster.
Old May 12, 2013 | 05:36 PM
zakevans21's Avatar
No need to be a **** about it. I wasn't comfortable on bending the trim over the steering wheel. I also didn't want to take the steering colum trim off. I was hoping there was an easier way. I know that you can directly hook into the ECM but I didn't want to dig around in those harnesses. I'm looking for advise. Not criticism.
Old May 12, 2013 | 07:44 PM
cjandura's Avatar
You have to drop the colum 2 14mm bolts ,2 trim screw on bottom panels,2 10mm bolts on crash panel,2 trim screws top of cluster.tapping the ecu gives issues you have to hit the green wire behind the cluster.
Old May 14, 2013 | 08:23 AM
02whitemaximase's Avatar
Nice
Old May 14, 2013 | 09:26 AM
FastnFuriousMax's Avatar
my gps works just fine and has for 4 years with the vss NOT hooked up fwiw.
MikesChevelle
Nov 23, 2024 11:17 AM
papo99
Audio/Video/Electronics
Aug 9, 2015 12:55 PM
maximaham
Aug 7, 2015 01:11 PM
Blackwind
Aug 5, 2015 06:35 PM
bassmann
Aug 3, 2015 07:53 PM
