Whats the best way to change the plug in cylider #3 on the VQ35
Remove upper intake manifold and elbow.
Highly suggest replacing rear valve cover while in there (using one from a 2004 Maxima). Also, if looking to do spacers, this would be the time to do that as well.
Also while you have your manifold off its a good time to clean the carbon out of it along with what others have suggested.
what process is there to forget on removing the UIM? There's 4 clamps, 3 bolts, 2 nuts, 1 electrical connection, and some pulling.
And 2 more clamps if you still have the TB heater/coolant connected though you probably dont have to remove that if you are just doing the plugs
Thanks everyone! what is the reason for replacing the valve cover on an 2003 with one from an 2004??
Attachment 4099
Attachment 4099
why does everyone get all replacement happy about the rear valve cover if the person hasnt reported oil? Its not like it causes any engine failures and there are tons of valve covers out there from 02-03 that arent causing leaks. If getting to replace the cover was some huge job that takes all day to do then it would make sense, but its only like 20 mins to pull the UIM, maybe an hour if its your second time and you struggle with tools
And I'd rather have the cover there for when I do plugs and /or coils so that I don't have to then have my AE down as I wait in parts that I can't even order till Monday (do my car stuff on weekend you see).
Then again my IM comes off in about 5-6 minutes tops.
Also, OP, learn to search while you're on here. A lot of basic spoonfeeding going on when this thread could probably answer all your questions and more.
http://forums.maxima.org/5th-generat...overs-pic.html
To me anyway, it's the simple ideology of "work smarter not harder." Why make more work for myself and add any additional cost of having to replace gaskets a second time when I can just do it at the same time? My time and money are valuable to me.
CAN-Toronto FS: Emanage Ultimate and plug/play Harness
knight_yyz
11-06-2015 02:34 PM
RWCreative
09-21-2015 11:01 AM
ag90fox
09-09-2015 12:22 PM
sdotcarter
09-02-2015 09:53 PM
