Front & Rear Footwell LED's/Glove Box LED
Old May 28, 2013 | 08:20 AM
The Duke of NY's Avatar
Finally finished my foot-well LED's. The front were kind of easy to install. The backs were a b*tch, due to having to do extra wiring. I tapped into the courtesy lights in the a-pillar. For the rears i ran wires from the same courtesy wire and ran down the seat-belt pillar, under the carpet, cut a small slit by the back of seat & pulled wire up through the floor. I put female quick connect/disconnects on the wiring & male connect/disconnects on the actual LED strip. This allows me to change/swap out strips with no problems & with very little effort. I then had to run wires for the passenger side under the headliner and down the seat-belt pillar on the passenger side. Here are pics of the final results: (They look alot brighter in the pictures)
Front
Back
Daytime shot
I had extra pieces of LED strip so i soldered in some new wires and installed it in my glove box. Here are the pics:
I wired the strip to the existing glove box light
Old May 28, 2013 | 09:04 AM
uptownsamcv's Avatar
that looks real good !!
Old May 28, 2013 | 09:11 AM
Stonelove670's Avatar
look nice man.
Old May 28, 2013 | 09:47 AM
cjandura's Avatar
Nice! glad you didn't do a color
Old May 28, 2013 | 10:10 AM
Brl24's Avatar
Looks good man, +1 on the non color choice, nice and clean.
Old May 28, 2013 | 11:10 AM
Thanks for all the compliments. If you look at the pictures of the rear LED's, on the passenger side in the corner, you can see a black wire coming from the floor/carpet. That is the 2 wires wrapped in electrical tape that connect to the LED strips, to give you an idea if anyone plans on doing the rears. Also the strips are held in place with 2 black zip ties. One on each end.
Old May 28, 2013 | 05:53 PM
NYTooCooL's Avatar
Anyone ever do it to where the lights are on when the doors are closed and driving?
Old May 28, 2013 | 06:18 PM
I'm sure its been done. You have to find a constant power source. One constant power source is the cigarette lighter underneath the climate control. For the rear you can use the accessory outlet above the cup holders on the floor.
Old May 28, 2013 | 10:28 PM
TunerMaxima3000's Avatar
Sick! Also love there is no Colour, great work
Old May 28, 2013 | 10:56 PM
Noir's Avatar
Way better than i imagined by the thread title. I especially like the glovebox light.. (I might just have a new mod to add to my "to do" list...)
Old May 29, 2013 | 12:54 AM
ranmas2004's Avatar
Yall both old fashioned. I have BLUE in mine now wha!! Dont care what yall think
Old May 29, 2013 | 01:11 AM
ttap97's Avatar
How did you mount it on the seats??
Old May 29, 2013 | 10:53 AM
I had blue in mine for ambient lighting but it was too much so I cut the wire, lol.
I never did anything for when I open the door since this mod, because it's crazy bright already:
http://forums.maxima.org/5th-generat...ome-turns.html
Old May 29, 2013 | 01:08 PM
Mounted the strips with zip-ties. One on each end of the strip. If you feel below the seat, there is a bar underneath the felt covering. That is what i mounted it to. Just make sure you move the strip enough so it is not showing.
Old May 30, 2013 | 04:52 PM
Shinjiduo's Avatar
Maxima Grounding Kit Spec
Excellent work Duke. Did you ever work out the HVAC lights?
Old May 30, 2013 | 09:14 PM
Going to PM you. I also sent a couple of customers for the grounding kit your way.... not sure if they contacted you yet.
Old May 30, 2013 | 10:45 PM
BlackThornDemon's Avatar
Looks good. Could you explain how you wired it though?
Old May 31, 2013 | 12:24 AM
TravisCadello's Avatar
HEYY!!! Why Don't I have constant power at my Cig Lighter! Neither one I hate it cuz i gotta turn key to charge my Phone.
Old May 31, 2013 | 07:41 AM
You shouldn't have constant power there iirc. Only when the key is on. Otherwise if you left a device plugged in, when you shut the car off the battery would die
MikesChevelle
Audio/Video/Electronics
Sep 11, 2016 06:36 PM
vybz05
Dec 10, 2015 07:38 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
jerrod99_se-l
Aug 22, 2015 04:14 AM
george__
Aug 18, 2015 07:06 PM
