2003 sub help
Old Jun 16, 2013 | 07:43 PM
lilblucoupe's Avatar
2003 sub help
ive read all the threads about the cut out, but my bose sub doesnt work at all. All the other speakers work fine. Is there a good way to trouble shoot this???
Old Jun 16, 2013 | 08:58 PM
Chris Gregg's Avatar
Get Off My Lawn
Check all the fuses?
Old Jun 17, 2013 | 05:24 AM
NIco2k's Avatar
I had the same issue with my 2001 infiniti i30 as well as my current 01 Max. They started ar a cut out and then stopped workin all together I want to say it was bad wiring.. but the bose system as u kno is a P.I.T.A to fix so I did aftermarket.
But my advice is check all the fuses and attempt to check the wiring but if all else fails just replace it with an aftermarket system for even better bass quality.
Old Jun 17, 2013 | 06:11 AM
Get Off My Lawn
Aging Bose systems just need to be replaced. since technology has advanced, its cheaper to replace the system with aftermarket for as good or better sound. If you want a replacement, I've got an 8" kicker sub with custom enclosure (mounted underneath) I'd sell. You would just need a small amp.
Only reason I removed it was because i bought a non-Bose Maxima and the 8" ended up not being enough bass for me. My '89 Max had two comp 12's and two comp 6x9's (subwoofer class)......so I got a 12" in a ported box for the trunk.
Old Jun 17, 2013 | 07:30 AM
yes ive checked the fuses and ive thought about changing it to aftermarket, just not sure i want to do that just yet.
Old Jun 17, 2013 | 07:37 AM
Zack342's Avatar
there is a bad relay in the amp. I have a working replacement amp for sale if you are interested.
Old Jun 17, 2013 | 07:49 AM
how do i know for sure its the amp??? hate to buy one and its not the problem. how much are you wanting for it??
Old Jun 17, 2013 | 08:06 AM
I35MyKe's Avatar
Had same issue in my i35, it was the amp
Old Jun 17, 2013 | 09:17 AM
djshwini's Avatar
If it turns out that the sub is actually bad, I have one that is ready to ship
Mahmuth
Aug 16, 2024 08:23 PM
Max139617
Oct 19, 2016 11:34 AM
Maximan190
Dec 16, 2015 06:01 AM
NewMax03
Oct 7, 2015 08:27 AM
