Changing driver side half shaft/axle
Old Jun 24, 2013 | 05:58 AM
bennuss's Avatar
Do I have to disconnect the struts or can I remove the lower ball joint and swing the hub off the axle?
Old Jun 24, 2013 | 06:09 AM
a33nismo's Avatar
When i do them at work i remove the lower ball joint nut, pop the joint out and then remove the shaft that way so i have the least amount of chance to mess up the alignment.
Old Jun 24, 2013 | 06:18 AM
bennuss's Avatar
Thanks that was why I did not want to remove the strut bolts
Old Jun 24, 2013 | 06:33 AM
Max_Gator's Avatar
I take out the strut bolts and disconnect the tie rod. You can swing the knuckle far enough to the side to work the axle in and out.
I get what a33 is saying about messing up the alignment, but I 've never had a problem. If you use my method, make sure you don't let the tie rod turn. Taking out the strut bolts shouldn't cause an alignment issue . . . unless you have a camber bolt.
Old Jun 24, 2013 | 12:25 PM
5aprilc's Avatar
Is two hours a fair amount of time it should take to do this job?
Old Jun 24, 2013 | 12:45 PM
rebelhell's Avatar
Yeah, two hours is probably right. I'm sure I could do mine in less than an hour but I've done it so many times (issues with bad shafts out of the box) that it's almost second nature.
Old Jun 24, 2013 | 12:50 PM
rebelhell's Avatar
I never disconnected the tie rod. All I did was unbolt the lower strut mount and un-clip the break line from its mount (so I didn't stretch it). You have to work it a little bit to get it out but it's not too bad at all.
Old Jun 24, 2013 | 05:08 PM
DennisMik's Avatar
I unbolted the brake caliper, detached the brake hose from the strut and unbolted the strut from the steering knuckle. I didn't touch the tie rod end or the ball joint.
Old Jun 24, 2013 | 05:26 PM
Claybob86's Avatar
When I did mine I just took the strut out. It's only 3 extra nuts inside the engine bay and opens up quite a bit of room.
fastcarny
May 18, 2020 10:40 AM
boomerbrian
Nov 8, 2015 05:10 PM
rtirbany
Sep 8, 2015 11:46 AM
shaunkey1
Aug 18, 2015 10:09 PM
