01 5spd tranny leak
01 5spd tranny leak
never figured out where leak is but leaks only when i top her off,gearoil is all on shift linkage bushing on tranny bottom,leaks about a quart then stops leaking...its a slow leak,well i havent put any in it past 6k miles its dry no leaks if i put finger in fill hole i feel its ALMOST full gears are smooth as butter.
question is should i be safe? shops say they gotta rebuild it.
well if it only leaks when you fill it up, the leak point is somewhere between the top and the point it stops leaking. Clean the whole area real good and then monitor the situation. The stuff has to go somewehre
fx4five
Oct 18, 2015 06:57 PM
ef9
Oct 4, 2015 08:43 AM
fx4five
Oct 1, 2015 04:58 AM
