Check engine light FLASHING, car sputtering
Old 07-23-2013, 09:55 PM
  #41
Scott LaRock's Avatar
I ordered the coil and the Sensor as stated and advised earlier, to get back on the road, if I need more sensors I'll buy those as well.
Thanks to rebelhell and everyone else for all the help.
Scott LaRock is offline
Old 08-04-2013, 06:31 AM
  #42
http://nissanhelp.com/diy/obd_codes/p0138.html
Think I need a new mechanic, he says I got the wrong o2 sensor. He's say he has a po138 code
Old 08-04-2013, 07:49 PM
  #43
DennisMik's Avatar
Originally Posted by Scott LaRock
p0133
p0572
p0430
p0305 cylinder misfire 5
You originally posted P0133, not P0138. Those codes are for different O2 sensors.
DennisMik is offline
Old 08-05-2013, 04:42 PM
  #44
Yes I know, after I changed the ignition coil, the P0133 code went away and now the p0138 code came up. That's what I was trying to say. My mechanic didn't change the p0133 because he says the po138 code is the problem not the p0133 so I was debating taking back the p0133 for the p0138.
Old 08-06-2013, 09:37 AM
  #45
How hard is it to install O2 sensors on our cars?
Old 08-06-2013, 09:39 AM
  #46
dot dot dot ...
NmexMAX's Avatar
Using the O2 sensor wrench, pretty easy. You can buy one or rent one. There are different designs. I'd go with the one that's completely open ended, vs the one with a cutout for the wiring. Better design.
NmexMAX is offline
Old 08-11-2013, 11:02 AM
  #47
Jesus Christ O2 sensor wrench? Smh...
I'm giving it a shot today, if I can't do it I'll take it to the mechanic next week.
Old 08-11-2013, 11:44 AM
  #48
george__'s Avatar
you should be able to rent one out from a auto store... Getting the old ones out could be a pain in the butt if you live where there is winter (you might need a torch)
If your exhaust needs work, maybe time for y-pipe + headers
george__ is offline
Old 08-11-2013, 12:13 PM
  #49
Do I have to use auto siege or whatever that protective grease is to put around the sensors and do I have to wait for the engine to cool completely before starting? I'm reading its best to wait 24 hours due to the heat and not wanting to warp the socket.
Probably for newbies it's bet to make the mechanic do it.
Old 08-11-2013, 12:14 PM
  #50
Yeah I may look into that y pipe and header thing soon.
Old 08-11-2013, 12:24 PM
  #51
DennisMik's Avatar
You should use an anti-seize compound on the threads of the new O2 sensor when you install it. If you don't, you may never get it out a year later.
You don't have to wait a day before installing the sensor. When you can touch the exhaust pipe without burning yourself, the time is right.
Old 08-11-2013, 12:34 PM
  #52
Okay I have to get that then, I'll rent the tool but I'm gonna wait till next week. And do it early morning.
Lakersallday24
06-16-2019 01:35 AM
Flores94
08-11-2015 12:53 PM
Team STILLEN
08-10-2015 04:29 PM
bassmann
08-03-2015 07:53 PM
Quick Reply: Check engine light FLASHING, car sputtering
