Could this cause a P0300?
Old Jul 23, 2013 | 09:41 PM
MaxinO2's Avatar
So I guess I still haven't figured the notorious PO300 code
and I though a motor swap with would solve it but no.
Iv'e been fighting this code for several years now on two separate motors , a lot of the parts were reused in the swap but I've done nearly everything to try and fix the PO300. So I was wondering if this solenoid was bad, which I can hear a hissing sound coming from. Do you think this could throw a PO300, it does have 2 vaccum lines running into it. I've heard that vacumm leaks can throw it but I'm not sure about this part.
Trying to get a little knowledge before I go out and spend $200. thanks
Its the middle one with the P1800
Old Jul 23, 2013 | 10:16 PM
so nasty nismo's Avatar
Purge valve solenoid bro I had that thing throw a p0300 code
Old Jul 23, 2013 | 11:41 PM
tosheto's Avatar
Why don't you hit up your local junk yard or look in the classifieds? 200 bucks is a lot for that one solenoid. If you kept your upper intake manifold when you did the swap (it looks to me like you did), then there is your problem.
Old Jul 24, 2013 | 07:47 PM
MaxinO2's Avatar
Sweet guys, I'll try and find one at a local salvage yard.. If not I called Nissan and they said they would beat courtesyparts at $150.. thanks
Old Jul 25, 2013 | 07:48 AM
Gemner's Avatar
NWP VIAS block off plate is way cheaper and better, and would eliminate that problem
Old Jul 25, 2013 | 08:08 PM
MaxinO2's Avatar
I have the block off plate but don't use it, I didn't like the low end loss.
I lucked out and found one at a salvage yard for $35, I've already installed the new one, well see if the code goes away in a few days.
Old Jul 25, 2013 | 09:05 PM
Child_uv_KoRn's Avatar
Bad *** Newb
IVT solenoids can stick hardcore, especially if the motor sits, and it doesn't have to throw a code for that except a random misfire.
wyche89
125
Nov 25, 2011 10:14 AM
Grand_hustle17
Dec 28, 2009 12:20 PM
abakalen
18
Jun 7, 2008 01:51 PM
PlanoSER
Aug 9, 2007 05:04 AM
MAXRB8
Feb 28, 2006 11:15 AM
