Camshaft Postion Sensor
Old Jul 26, 2013 | 12:45 PM
DetroitWings's Avatar
Hey,
I'm new here! My 3.5L 03 Maxima's check engine light came on and has code P0011. Everything seems to be fine so I think the CPS might be bad. Where could I find the CPS and do ya'll think it could be the same problem?
Thanks in advance!!
Old Jul 26, 2013 | 12:48 PM
Chris Gregg's Avatar
Get Off My Lawn
Should also call your local dealer and see if it has had the cps recall done. Mine had not, so I had them do it last year. Can't beat free.
Old Jul 26, 2013 | 07:40 PM
Brudface's Avatar
There are 2 cam shaft position sensors. Extremely easy fix as they are held in with one 10mm bolt I believe. They are both on the drivers side of the motor on the cylinder head JUST underneath the valve cover. You can't miss it, its the only sensor on the heads. But before you replace do as Chris said and stop by the stealership and have them run your VIN. Do NOT cheap out on this part purchase oem only as the aftermarket ones are garbage.
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
