NWP 75 mm throttle body installed, first thoughts
Old Aug 21, 2013 | 09:57 PM
  #121
knight_yyz's Avatar
Toolie
Ready for ceramic coating
Old Aug 22, 2013 | 09:15 PM
  #122
knight_yyz's Avatar
Toolie
Sorry, apparently i typed 80mm TB when it should be 75. my bad
75mm Tb with 80mm BBMAF
Old Aug 23, 2013 | 12:04 AM
  #123
tcb_02_max's Avatar
And I was thinking this whole time, "Where is he getting an 80 mm throttle body from?"
Old Aug 23, 2013 | 03:59 AM
  #124
CauzinDrama's Avatar
I was thinking maybe the 75 was enough for him... Lol
Old Aug 23, 2013 | 10:42 PM
  #125
melvinman2003's Avatar
One suggestion. I recommend doing the throttle relearn procedure. I noticed my idle jumped up more then usual. I did the throttle relearn and it is idling like it should. It should increase mpg since idling eats gas.
Old Aug 24, 2013 | 05:49 AM
  #126
95VQ30's Avatar
Upon initial start up, my car will idle high(around 1k) for a minute or two. But then returns to a steady 710ish
Old Sep 2, 2013 | 05:01 PM
  #127
SicX6spd's Avatar
hey knights, any update the bbtb setup?
Old Sep 3, 2013 | 01:39 AM
  #128
knight_yyz's Avatar
Toolie
well, the BBMAF completely messed up my timing, so i lost a lot of bottom end, and gained nothing at the top end. At this point I still have it on the car but i haven;t decided on how to proceed.
Old Sep 19, 2013 | 03:39 PM
  #129
Switched back to a SRI set-up and it fells much more responsive than the WAI I had configured.... And my IAT still reading 13 degrees over air temp at highway speeds.
Old Sep 19, 2013 | 04:04 PM
  #130
NmexMAX's Avatar
dot dot dot ...
So, what exactly is the difference between your SRI and WAI?
Old Sep 19, 2013 | 04:11 PM
  #131
For the warm air intake I had the filter routed and tucked behind the headlight. And for the short ram I have it right to the mass airflow housing with an adapter. So I shortened it a total length by about 14 inches.
Old Sep 19, 2013 | 04:21 PM
  #132
NmexMAX's Avatar
dot dot dot ...
Ahh, yeah I like that set-up best too so far. Which is over a decade or so of fitting and dyoing.
Old Sep 19, 2013 | 04:39 PM
  #133
TexasTex's Avatar
Alright, so come on. What is the best aftermarket bolt on intake? I have read so many different things here. I'm confused!
Old Sep 19, 2013 | 04:53 PM
  #134
I haven't done any type of dynoing, since I go by how the car feels I'd say short ram intake takes the cake here..... I have only like 12-14 inches between the filter and TB.
Old Sep 20, 2013 | 06:36 AM
  #135
NmexMAX's Avatar
dot dot dot ...
Bolt on: JWT/Stillen,
Best performance: Custom, 77-100mm MAF ID w/ associated piping, not for the faint of heart as it requires addition items. PM me if more info is needed and I'll provide links.
Now let's not deviate from this thread.
Old Sep 20, 2013 | 12:38 PM
  #136
95VQ30's Avatar
any third party before/after dynos yet.
I saw some Z guys were saying there was no gains
Old Nov 10, 2013 | 02:03 PM
  #137
mikehawk's Avatar
I've been reading the same.
http://my350z.com/forum/intake-exhau...ttle-body.html
Does anybody have anything to substantiate NWP's claims of 8whp on a stock-ish max? I know dyno time can be expensive, but what about track time? 8whp should be good enough for at least a mph, right?
I'd really like to hear from somebody with a 3.5" or 4" intake, but at this point I'll listen to anybody that can share more than a feeling about the throttle body.
Old Nov 10, 2013 | 06:05 PM
  #138
george__'s Avatar
I got this and a 4" maf kit coming if you can wait until 2014 for dyno
Old Nov 10, 2013 | 06:17 PM
  #139
mikehawk's Avatar
Are you talking about getting the 4" MAF tuned with the stock TB, then bolting on the 75mm TB for a final comparison run while the car is still strapped on the dyno? That would be awesome to get that kind of definitive proof.
Old Jan 4, 2014 | 09:49 AM
  #140
jjubert's Avatar
Just connected my NWP TB...I started the car and warmed it up, my idle eventually came down to 788 rpm...Is the throttle relearn necessary at this point?
Old Jan 4, 2014 | 10:16 AM
  #141
Yes
Old Jan 4, 2014 | 10:24 AM
  #142
jjubert's Avatar
Yes
Oh well guess it's time to pull out my stop watch and get to pedal mashing, wish there was an easier way...the instructions make it seem like a tedious task
Old Jan 4, 2014 | 11:42 AM
  #143
jjubert's Avatar
Yeah soon as I restarted it threw a code, relearn done...it was easier than I thought! I can also tell a difference in response time, i'm pleased so far now on to the next mod!
Old Jan 4, 2014 | 12:21 PM
  #144
Very good..... You will love the top end pull with the new TB. It will give you the Mod bug, it sure has done it to me.
Old Jan 4, 2014 | 12:41 PM
  #145
clintb3astwood's Avatar
I've had the 7th gen tb on my car for about 3 months now. My manifold has ssim, bop and the spacer kit so I noticed the throttle response is much more responsive and it pulls a lot harder. Even in 6th gear if step on the car and there's no lag it felt like it still wanted to pull. I then installed the 4" intake along with a few other things, street tuned the car and HOLY ****. the car feels like it wants to pull forever, if you have a small intake with the bigger tb you are holding back so much more potential power.
Old Jan 4, 2014 | 12:59 PM
  #146
I'm looking for a decent priced apexi because of your reviews on the tune and stuff Clint.
Old Jan 4, 2014 | 03:50 PM
  #147
Make sure whoever installs the apexi knows what they're doin and does a clean job.
Old Jan 5, 2014 | 01:42 PM
  #148
maximaminimum's Avatar
Originally Posted by mrjasonlyrics
Relax home boy. I was just bringing it to his attention. I'm just saying if he was to do it how do you know he's going to stop at the speed limit and not exceed it? Isn't the purpose of the "performance mod" to give gains? And yes it is illegal in every state to have a hand held device while operating any vehicle. Instead of jumping on what I said why not give him some advice like have someone record it while you're driving and obeying the speed limit.
I will never understand why you bullies pick fight on such small topics and make nothing outta something. You're a senior so I think you should act like one. Little disputes like this turns into huge arguments and this site just have too much of it. Just saying
I hate to bring out old topics from the thread but...
Its not illegal in the state of Missouri to operate a handheld device while driving...
Old Jan 5, 2014 | 03:01 PM
  #149
CMax03's Avatar
Actually here in Texas it's not against the Law yet for non CDL vehicles....Even our cops text and drive, or operate thier laptops in transit!
Old Jan 20, 2014 | 10:43 AM
  #150
mikehawk's Avatar
Any updates? Dyno comparison? New 1/4 mile PB?
Old Jan 21, 2014 | 12:56 PM
  #151
zachpark17's Avatar
Hey guys, haven't been on the forum long, but always read all of the forums for a couple years. Just decided to make an account so I can actually have a say on things lol. No one has really said anything about the BBTB. Right now I have a custom 3" SRI, VIAS block off plate on the IM, the 5-piece phenolic IM spacer kit, custom 2.5" exhaust cat-back, ngk lasers, stagg performance struts/ vogtland springs, timing advanced to 17~18 BTDC, probably more I just can't think right now. Anyway, my question is will the new BBTB really make that much more of a difference with the 3" Short ram intake and the stock manifold with the spacers? I feel like the car is getting as much air as it can right now, how will the TB change that at all? Thanks guys. Also, to the guy who said he was loving more of the 3rd gear chirps, what do you have done to yours, because I'm getting third gear chirps as it is right now.
vingodine
45
May 21, 2016 12:46 PM
iflexsteel
Sep 15, 2015 03:37 AM
homewrecker
Aug 24, 2015 08:56 PM
Samedi
Aug 13, 2015 04:05 PM
