Electric Motor disconnect
Old Aug 25, 2013 | 03:20 PM
CauzinDrama's Avatar
OK so I disconnected my front motor mounts for experimental purposes and I was wondering something..... How would the mount do if I connected a 12v switch to it to stiffen it up while driving. I like the being disconnected to save the ecu from a possible shortage, but I can feel movement in the engine. Thoughts?!?!?
Old Aug 25, 2013 | 03:56 PM
george__'s Avatar
You worry too much, just plug it in and be happy if you don't like stiff
BUT if you like stiff go get some polyurethane mounts
Old Aug 25, 2013 | 04:14 PM
Rods03Max619's Avatar
Or maybe your mounts are already shot as it is...
Old Aug 25, 2013 | 04:53 PM
Its quiet possible that the mounts could be replaced but they are not noticeably worn. I dont want the Poly mounts thats too much stiffness. I was just looking to maintian the factory feel without the chance of the ecu shorting out on me. Maybe I am worrying too much.
Old Aug 25, 2013 | 04:59 PM
george__'s Avatar
Get new ones from Nissan then
Old Aug 25, 2013 | 05:36 PM
knight_yyz's Avatar
Toolie
If you want factory feel replace the trans and passenger mounts with urethane and leave the torque mounts alone
Old Aug 25, 2013 | 06:17 PM
Who does the poly mounts here?
Old Aug 25, 2013 | 06:20 PM
george__'s Avatar
The guy above you. Knight!
Old Aug 25, 2013 | 08:22 PM
Donkeypunch's Avatar
Get the Ebay ones. They are manuals and it's OK. Not too harsh.
You'll need longer bolts for the passenger and driver side, but it's direct bolt on.
Old Aug 25, 2013 | 08:37 PM
If I were to go that route those would be nice but I don't have a press. I would prefer to buy a set done already.
Old Aug 26, 2013 | 01:43 AM
knight_yyz's Avatar
Toolie
I can sell you a set of poly's already pressed in.
Old Aug 26, 2013 | 03:40 AM
What are we talking for price shipp d to 02649
Old Aug 26, 2013 | 12:54 PM
knight_yyz's Avatar
Toolie
for an auto? aluminum or steel?
Old Aug 26, 2013 | 12:58 PM
For an auto 2k2 and which ever is cheaper so presumably steel.
Old Aug 26, 2013 | 03:53 PM
knight_yyz's Avatar
Toolie
tried to pm you back but your inbox is full
My mounts will bolt right up with no pressing in or out, that will already be done for you in this case. There is also way less vibration than the ES torque mounts.
Old Aug 26, 2013 | 04:03 PM
Bolt on that's pissah!!!!!! So these will replace which mounts
Old Aug 26, 2013 | 06:59 PM
knight_yyz's Avatar
Toolie
the drivers side and the transmission mounts.
Old Aug 26, 2013 | 07:07 PM
george__'s Avatar
That won't make the car shake on idle?
Old Aug 26, 2013 | 07:08 PM
Pm sent
Old Aug 26, 2013 | 08:48 PM
Chris Gregg's Avatar
Get Off My Lawn
Yes, there will be added vibration with poly mounts. If that is definitely a concern, just go with a stock replacement for only the two engine mounts. Might as well replace them both while under there. May feel a slight vibration at idle, but only minor.
For anyone less concerned about vibration (as an automatic), then get manual engine mounts and one or both of Knights Wrayth mounts. I personally have the passenger side torque mount, the tranny was too much for me so I removed it. So I kept the tranny mount stock.
Old Aug 26, 2013 | 09:17 PM
I'm going to give them a shot and see how it goes. I like a nice smooth idle and ride but we will see how it goes. If I don't like it I can always try and resell em. I will have my old ones just n case.
Old Aug 26, 2013 | 09:40 PM
george__'s Avatar
the vibration dies down eventually...
Old Aug 26, 2013 | 10:01 PM
These are the actual brackets with bushings.
I recently changed mine and don't recommend poly.
http://www.ebay.com/itm/271032617498...S:3160&vxp=mtr
You really want to deal with harshness in a nice maxima?
Manual trans replacements are very stiff.
super hard rubber compared to the auto.
I'll ban myself if you
think you need poly.
Old Aug 27, 2013 | 01:50 AM
knight_yyz's Avatar
Toolie
There is no added vibration if you put poly mounts on the upper mounts only. I have done the install on this on 3 cars without energy suspension torque mounts and you barely tell the difference. It is not the same thing as doing the torque mounts in poly.
Yes it is rough if you do all 4. But the side mounts are barely noticeable.
Since I am the only person who makes upper poly mounts please explain to me how you absolutely know for sure that my mounts will provide a harsh ride? I'm pretty sure you have not bought a set of them from me.
The manual mounts do not use a harder rubber. They are smaller if you are talking about the torque mounts. So they might seem harder. But the side mounts are the same size, and the manual mounts have much bigger gaps than the auto mounts
In this picture the manual mount is on the right. Tell me how it can possibly be harder than the one on the left. This is the passenger side upper mount from and auto and a 6mt.
Old Aug 27, 2013 | 11:00 PM
Is that a stock mount with poly caulked on it?
I thought you were talking about real aftermarket poly mounts.
The rubber is harder on the ebay mounts then the stock ones
definitely.
Old Aug 27, 2013 | 11:04 PM
Fakie J Farkerton's Avatar
definitely.
Seriously?? Wow.
Old Aug 28, 2013 | 01:43 AM
knight_yyz's Avatar
Toolie
As opposed to my fake aftermarket poly mounts? What the hell is that supposed to mean? Perhaps you should slow down and read it again. Both those mounts in the picture are stock oem mounts. One is an auto, one is from a 6mt.
The rubber is harder on the ebay mounts then the stock ones definitely.
So you are saying, you bought a new set of oem mounts and had them tested with a durometer, then bought an ebay set and tested them as well. Please give us the numbers, I would love to know the difference.
Here's the photo of the "fake" aftermarket poly mounts. Durometer 70a
LMFAO
Old Aug 28, 2013 | 02:12 AM
Old Sep 14, 2013 | 11:36 AM
OK so I got the mounts installed today and WOWWA what a difference. The engine feels a lot set in its place. Feels like it's one with the car... Honestly I love the throttle response improvement from there being less movement in the engine and transmission.
1 thing I did do was bump my idle up 100 rpms. When it was in the upper 600s you could feel some vibration. Smoothed right out when it's idling in the upper 700s.
Thanks for the quality work Knight.
Old Sep 14, 2013 | 03:04 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Prerequisite: Don't be a whiny *****
Step 1: Remove mounts
Step 2: Clean all rubber well
Step 3: Buy window weld or equivalent.
Step 4: Ooze that **** all over like the mount is Scarlett Johansson (you may have to do it a couple times to properly fill in the gaps and outside areas to keep it from running)
Step 5: Let dry for a day, then reinstall
It's cheap and very effective.
Old Sep 14, 2013 | 08:39 PM
Originally Posted by tomcat
Isn't the engine mount/ECM issue a '00-'01 problem? I guess I really haven't seen many 5.5's talk about this issue.
Its a 5.5 auto issue.... The mount is wired straight to the ECU.
Old Sep 15, 2013 | 09:56 AM
knight_yyz's Avatar
Toolie
But it doesn't fill in the gap between the rubber mount and the bracket. My mounts fill in that gap which acts as a minor torque mount.
Old Sep 15, 2013 | 09:58 AM
And they look damn good in the black powder coat.
AaronL
Aug 8, 2020 10:31 AM
Unclejunebug
Apr 2, 2016 05:42 AM
leatherneck
Sep 30, 2015 09:16 PM
maxima297
Sep 30, 2015 03:32 PM
