Engine Cranks but No Start
Old Aug 29, 2013 | 11:12 AM
panabiker's Avatar
2002 SE, 180k miles. I had been driving it everyday normally but since this morning it won't start. It cranks normally so I don't think battery or starter was the cause. I did check the cam shafts and they turned when engine cranked so the timing chain is not broken. Now, I run out of ideas as to where to check. I know it's either not getting the spark or not getting fuel but what's the easy way I can tell without disconnecting many things? I also have an OBD-II thing but I don't think it will tell anything if the engine couldn't even start.
Old Aug 29, 2013 | 12:35 PM
tosheto's Avatar
Pull out one of the front coils and take out the plug. Put the plug back in the coil and set on top of the engine or radiator support (ground). Crank it and if you see spark you are good there. Then pull off the fuel line on the driver side of the engine and see if you get fuel when you crank. If one of the above things is missing you found your problem.
Old Aug 29, 2013 | 08:16 PM
DennisMik's Avatar
Check for codes. It might have something. All you need is the ignition turned on to read codes. The engine does not have to be running.
Is the red security led on solid while you are cranking the engine? If yes, the NATS has disabled the car.
Old Aug 30, 2013 | 07:39 AM
panabiker's Avatar
Thanks for the suggestions. I just checked the code. They are P1610 and P1612. From the service manual, they translate to NATS MALFUNCTION. I assume this would prevent the engine from start?
By the way the security LED is not lit.
Old Aug 30, 2013 | 01:22 PM
panabiker's Avatar
Well, actually, the security LED does come ON after leaving the ignition key at ON position for about 5 sec,
Old Aug 30, 2013 | 04:45 PM
boris's Avatar
Start searching from the easiest, i.e. check fusibles first.
Old Aug 30, 2013 | 05:54 PM
2damax's Avatar
When you say the security light is on do you mean a solid light or a flashing light? Go crank the car and watch the light. If solid then that is your problem.
Were there any symptoms or recent work prior to this? No random lights or anything?
Old Aug 30, 2013 | 06:45 PM
panabiker's Avatar
Yes, the security LED is on solid for as long as I leave the key at ON position.
No recent services and no check engine light before this happend.
I remove the battery yesterday for recharge because it was drained after the repeated cranking. So the code check was done after the re-installation of the battery.
I did check the fuses that has connections to NATS and ignition control.
Old Aug 31, 2013 | 06:10 AM
2damax's Avatar
Do a search for the common NATS issue. That seems to be your problem. It has never happened to me but I think you can have a locksmith come over and reprogram it for you. Not terribly expensive.
Old Aug 31, 2013 | 07:08 AM
panabiker's Avatar
Yes it points to NATS problem. The factory manual says to us Consult II to reprogram the NATS with keys. You think a locksmith has the necessary tool to reprogram the NATS unit?
Old Aug 31, 2013 | 08:45 AM
2damax's Avatar
From what I have read on others threads (and from a coworkers story) it is possible to have a locksmith come to you. Otherwise you are looking at a tow fee and a dealership fee. You just have to find the locksmith that can do it. Maybe someone that has done it before can chime in and tell you exactly what you need the locksmith to be capable of.
The FSM is a great tool. But of course it will say you need the dealership. They won't tell you there is a cheaper and more convenient option.
Old Oct 24, 2013 | 10:55 AM
NIMAX03's Avatar
Check the post I started for some Info regarding to this. I Along with a lot of other people are seeming to have this problem more and more.
Theres some info about half way down by me that should help.
cruce91
Sep 20, 2015 10:23 AM
conansriver
Sep 3, 2015 06:38 AM
305head
Aug 26, 2015 09:03 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
