2000 O2 sensor wiring Fed Spec
Old Aug 29, 2013 | 01:12 PM
TDotMax's Avatar
There seems to be a lot of confusion as to which O2 sensor goes onto a fed spec, even on Canadian sites.
Does a 00' Fed spec have 2-3 wire O2's and 1-4 wire? Or 2 4-wire and 1 3-wire?
I'm pretty sure the 4 wire is the rear but there is confusion with the front when ordering.
Old Aug 29, 2013 | 07:27 PM
DennisMik's Avatar
Fed spec cars use two 3-wire and one 4-wire O2 sensors.
The sensors that monitor the gas coming out of the exhaust manifold are the 3-wire ones and are referred to as "upstream" sensors. The one after the catalytic converter is the 4-wire sensor and is referred to as the "downstream" sensor.
Old Aug 30, 2013 | 04:30 AM
TDotMax's Avatar
Thats what I thought. Thanks for confirming.
Old Aug 30, 2013 | 10:53 PM
defiance's Avatar
Can a malfunctioning Bank 1 Sensor 1 trick the computer into thinking that Bank 1 is running lean ? Thereby the computer dumps in more fuel...messing up the idle when hot ?
The Frye
Sep 2, 2021 11:03 AM
9aj9
Apr 5, 2020 12:11 AM
dcardello
Sep 3, 2015 11:44 PM
Samedi
Sep 3, 2015 01:07 PM
