Prolonged suspension issue
Old Sep 11, 2013 | 11:20 AM
IceBerg's Avatar
I'm at wit ends the problem is that from time to time my shocks feel blown then randomly it doesn't (not motor mounts) at other times its uncomfortably stiff ,and for some weird reason when it's stuff it is because there is the bumpstops have no room for play example the bump stop touches the shock and the top hat at the same type these are kybs btw with about an inch drop lowering spring
Old Sep 11, 2013 | 11:42 AM
2damax's Avatar
Are the dust boots oem? You could try cutting the stops a little bit. I have a similar setup and it is certainly a more stiff and bumpy ride but I don't bottom out like you describe.
A suspension expert will likely chime in soon. Don't forget to post in DJ's thread.
Old Sep 11, 2013 | 11:52 AM
IceBerg's Avatar
Yea I had to cut it after the original install because it had no play it was fine but now it had no play again and I don't wAnt to remove the bumpstops and risk any damage and no dust boots are not oem
Old Sep 14, 2013 | 06:28 AM
IceBerg's Avatar
anymore insight
Old Sep 14, 2013 | 06:48 AM
2damax's Avatar
Did you post in the suspension thread? You will get some good info there.
Mar 12, 2020 12:06 AM
mikeg75
Nov 30, 2015 05:12 PM
240tomax
Sep 13, 2015 03:28 PM
Violator
Sep 9, 2015 10:14 AM
A32goldylocks
Sep 2, 2015 06:39 AM
