Leaking oil after valve cover change
Old Sep 14, 2013 | 08:20 AM
blackbeasst's Avatar
Not even a week after we replaced the vc I wake up to a half dollar and dime size oil spot this morning.
It couldnt have already started could it?
Old Sep 15, 2013 | 02:19 PM
Shift_A32B's Avatar
You have to trace where that recent leak came from.
If its coming from the VC, then probably you didn't tighten them in the correct pattern or you didn't put enough sealant in the crucial places (which you would have to look up in the How-to stickies).
Old Sep 15, 2013 | 04:35 PM
nah we had the step by step how to on what to do.
and i think i jumped the gun a little. what was "leaking" was way too liquidy to be straight oil. i think what happened was water from the ac dripped down onto some oil that was already in the garage and made it look like fresh oil
Old Oct 21, 2013 | 12:18 PM
yup, its official. still got an oil leak after the replacement.
sure as hell don't feel like taking everything apart again. any ideas?
Old Oct 22, 2013 | 06:41 AM
03GLEmaxima's Avatar
Did you clean the gasket surface on the head thoroughly? Check the drain plug, oil cooler. Spray brake clean and clean it all up then drive around a few days and find out exactly where its coming from...
Old Oct 22, 2013 | 09:12 AM
yeah we cleaned it good. the guy who helped me is very meticulous about that kinda stuff since he races and works on his miata every weekend!
also, from the time i initially made this thread it stopped leaking. and now it has up and started again.
Old Oct 22, 2013 | 09:50 AM
george__'s Avatar
By valve cover you mean this thing?
I followed this guide http://www.cardomain.com/ride/694281...axima/page-13/ and used tiny bits of RTV black on the corners and in the middle... I also bought the Gen 6 ones (front/rear)
Old Oct 22, 2013 | 12:21 PM
yup. and i also got 6th gen ones. we didn't follow that guide, but the other one thats floating around to the T
Old Oct 22, 2013 | 01:34 PM
george__'s Avatar
yeah maybe try reinstalling and use something like rtv... I really like it, used it for the oil pan too and zero leaks
Old Oct 22, 2013 | 05:26 PM
nestorlugo's Avatar
^^ yo i did this job on my 3.0 a few months ago and it was pretty straight fwd,main thing is use some sort of sealant on all four corners(crucial places to others) And DO NOT OVER TIGHTEN.
blackbeasst looks like you and your buddy will be doing the job over again(but like my Dad used to say "Oh you've done it ones,now it should be half's difficult"
Btw,
Do not reuse ANY
gaskets.
Old Oct 22, 2013 | 06:21 PM
im starting to think something else is causing it to start to leak. what i just found out looking at some paperwork when i bought the car back in july was that the previous owner had it done as well back september 2012. so what are the chances of it happening twice in 12 months?
Old Oct 22, 2013 | 07:10 PM
nestorlugo's Avatar
Just read up on rear main seal the rear should be the culprit of you leak if its not the vc...also check crankshaft pos sensor those trend to leak and burn alternators...
Matt93SE
Apr 8, 2018 09:23 AM
maximusrising
Sep 2, 2015 09:55 AM
Maximeltman
Aug 31, 2015 01:01 PM
Nintensity
Aug 13, 2015 05:41 PM
RealityCheck
Aug 5, 2015 06:18 AM
