Cannot pull out the MAF connector (Images attached)
Old Sep 14, 2013 | 05:50 PM
"legal"streetracer's Avatar
I'm not sure what i am supposed to do here with this MAF connector. I've pushed down and tried to pull it out, i've even tried pinching it and pulling it out. Doesn't seem to work, so I was wondering if it is actually not the factory installed connector. Anyone have some tips?
Old Sep 14, 2013 | 06:09 PM
Fakie J Farkerton's Avatar
Flathead screwdriver and elbow grease.
Connector tabs are fun.
Old Sep 14, 2013 | 07:02 PM
So What exactly am i supposed to do with the flathead? push the tab down?
Old Sep 14, 2013 | 07:15 PM
Ghost_54's Avatar
No the connector has a pinch tab, so push the tab inward while pulling up on the connector ... as stated above connector can be such fun, keep at it you will get it to pull up and off (I trust you have disconnected the battery?) always a wise thing to do when working on any electrical componet.
Old Sep 14, 2013 | 07:25 PM
I've disconnected the negative terminal, I don't really have any plans on being electrocuted any time soon.
Old Sep 14, 2013 | 07:30 PM
george__'s Avatar
flat head screw driver and use that as leverage for the clip
Use the flat head and push down on the plastic clip, then hold the connector (plastic part not cable) and pull back
Old Sep 14, 2013 | 07:31 PM
Ghost_54's Avatar
Disconnecting the battery is not to keep you safe (as if a 12 volt battery would hurt you) it is to protect the sensor that you are about to disconnect from any surge and thus burning it out.
Old Sep 15, 2013 | 01:53 PM
TriniSpeC's Avatar
On a side note why is it so dusty??
Old Sep 15, 2013 | 03:52 PM
-ReLLiK-
Apr 29, 2016 06:25 PM
6spd4dsc
Mar 4, 2016 05:19 PM
JoshG
Sep 16, 2015 08:56 PM
