DS Front CV Axle Replacement
If all goes well, yes. If your car is a manual then typically you can pry it out, but be careful you don't damage the axle seal...or better yet get a new axle seal or two(spare) and replace it as they have a way of getting buggered up on removal/installation of the axle if you're not careful. If your tranny is an auto I recall it's sometimes hard to get the DS side axle out and may ultimately require you remove the passenger side axle so that you can drive out the DS axle from the opposite side (through the PS axle hole). When you reinstall the axle suggest you grease the seal so the axle slides in more easily and you diminish the risk of damaging the seal. A little nick in the seal will p*&s tranny fluid.
vingodine
45
05-21-2016 12:46 PM
kingw323
20
10-21-2015 08:36 AM
