Battery went dead, now it won't start
Old Sep 20, 2013 | 05:31 AM
mmitchell29's Avatar
I've seen several posts about this subject, but haven't really seen an answer particular to my situation. I have a 2002 Maxima that sat for about a month thus the battery going dead. Well, without unhooking the battery placed a battery charger on it charging the battery. Once charged, it cranks but does not start, at all, doesn't even try. It was running fine when parked and the only problem was the battery going dead. I can hear the fuel pump priming up when I turn the key on, I've checked the timing chain, plugs are good. I'm just not sure what else to do, so if anyone has any other suggestions I'd appreciate it.
Old Sep 20, 2013 | 07:24 AM
TunerMaxima3000's Avatar
Security light is probably on solid.
Try to cycle the key on for a second then off for 10 seconds. Do this until the security light goes out. If this doesn't work, you may have to clear the faults (if there are any) out of the ECM with a scan tool.
Another option is disconnecting the battery for a few hours or overnight and trying again by connecting the battery and unlocking the car with the fab.
Of course, this is assuming that the security light is on solid.
Old Sep 20, 2013 | 07:48 AM
george__'s Avatar
I drained the battery on my Maxima a few times before due to dashcam. Each time this happened I used jumper cables and it started fine but I know my battery is working
Old Sep 22, 2013 | 06:59 PM
gapboi210's Avatar
ok and...........?
Old Sep 23, 2013 | 06:33 AM
Nevermind George he just likes to post useless commentary that most often makes no sense or barely relates to the thread at all.
Old Oct 3, 2013 | 07:08 AM
No, my security light is NOT on at all.
Did you ever find a resolution?
I'm completely baffled.
Old Oct 3, 2013 | 10:01 AM
TDotMax's Avatar
I had this issue when I had mine parked up. Turned out to be some sort of fuse. Not sure which one but my mech had to order it from the dealership.
Old Oct 3, 2013 | 10:25 AM
DennisMik's Avatar
In the fuse block under the hood by the battery, check two fuses. The cover has them labeled ENG CONT 1 and ENG CONT 2.
Old Oct 5, 2013 | 01:24 PM
I found the fuses ENG CONT 1 & ENG CONT 2. Both show continuity, as well as all other fuses and relays, under the hood.
Old Oct 5, 2013 | 02:10 PM
ajahearn's Avatar
I had a case where the battery charger indicated everything was fine but the battery had an internal short which killed any chance to start. After replacing the battery it ran fine. Have you tested the battery?
Old Oct 5, 2013 | 02:33 PM
george__'s Avatar
Do you have aftermarket stuff installed in your car?
It could be draining your battery when you don't drive the car for x amount of days
Old Oct 5, 2013 | 10:26 PM
gapboi210's Avatar
+1
We had a car come in the shop the other day. The lights all turned on bright, battery showed 12.1 volts but the second you tried to start it, it would die. Had an internal short in the battery. Pretty common especially with Interstate batteries. They put the plates very close together for more cranking amps.
Old Oct 6, 2013 | 08:03 PM
No aftermarket products whatsoever, i.e. no alarm, no aftermarket stereo, completely stock car. Battery will take a full charge and crank continuously (without a charger) until it's dead.
Old Oct 6, 2013 | 09:26 PM
DennisMik's Avatar
For the car to start, 3 things are needed - air, fuel and a spark. You need to find out which one is missing. I'm willing to assume it is getting air so that leaves fuel and spark.
Take off any one of the coil packs. Also take the spark plug out for that cylinder and then plug it into the coil pack. With the wire harness plugged into the coil pack and the spark plug grounded to metal, have someone crank the engine and see if there is a spark happening at the end of the spark plug.
Old Oct 8, 2013 | 05:52 PM
^That. Once you confirm you have spark you can investigate fuel.
Does the car have any engine codes?
Old Oct 8, 2013 | 06:09 PM
TexasTex's Avatar
Try another battery.
Old Oct 8, 2013 | 06:25 PM
gapboi210's Avatar
I dunno if I would suggest another battery if it is able to crank for a long time. While someone is cranking, try shooting some carb cleaner into the throttle body and see if it tries to run that way.
Old Oct 8, 2013 | 07:00 PM
TexasTex's Avatar
I did exactly that on my girls Honda not too long ago and it fired right up. Her car had been sitting for over a month and the battery died. I charged it on a charger for three days and got a solid charge but it wouldn't start after cranking for minutes at a time.
So I put the battery from the Maxima in it and it fired it right up. I ended up taking the battery back to Costco to warranty it out. New one worked great and we sold the car.
Old Oct 11, 2013 | 02:30 PM
chetubar's Avatar
Hi! I had the same problem yesterday, i sat my maxima for about one month and the battery going dead, the battery was removed to recharge it, once charged, i put it back, my car cranks but didn't start. After one day trying to start it checking fuses and all the basic things that you have to check the solution was very easy and it was the last thing that cross by my mind before take my car to the shop. I just press the unlock button in my key control remote for 5 seconds then the Windows went down and thats it my car start perfect, i think when you remove the battery the safety system is activated. Good luck!
Old Oct 13, 2013 | 10:37 PM
berniek's Avatar
Spark checking
There is no need to pull the spark plug. Shove a #1 Philips screwdriver into the coil high tension hole, and see if you get an arc from a GROUNDED clip lead when cranking. Be sure the clip lead is grounded or you will get a nasty shock.
If you have spark, see if the engine does anything when spraying starting fluid into the intake. The probable best way to get to it is to remove the air filter from its housing. I can't vouch for absence of damage to the MAF, but there is no reason I know of that ether/heptane mixture (starting fluid) would harm it.
Hope this helps the start of diagnosis.
Old Oct 22, 2013 | 03:34 PM
I'm getting no spark at all.
Old Oct 22, 2013 | 07:15 PM
DennisMik's Avatar
There are many things that could cause the problem. The fusible link under the hood labeled "FL80A MAIN 1", the crankshaft sensor, the camshaft sensor, the ignition relay and more.
Do you have 12 volts on the red wire of the ignition coil connector? This could be another bads fuse, under the hood labeled "ENG CONT 1".
Old Oct 22, 2013 | 09:54 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Yeah, kinda sounds like one of the sensors went bad since everything else is checking out.
Old Oct 23, 2013 | 05:40 AM
Max_Gator's Avatar
Have you tried another battery yet???
Old Oct 24, 2013 | 04:37 PM
Yes tried another battery today. I just hate to pay dealership prices but it seems that may be my only resolve.
Old Oct 24, 2013 | 04:45 PM
I've even went as far as removing the ECU and opening it up to find nothing apparently wrong/burnt, after reading another thread where someone had an ECU go bad after learning the IAC motor had locked up, only to find it was the active motor mounts creating the original issue.
Old Oct 24, 2013 | 04:50 PM
Gemner's Avatar
if you have an FSM, follow the no start checklist. If you dont have an FSM, start with getting an FSM and then follow the no start checklist
I believe there is a fuse in the fuse box inside the cabin, I would check on that first.
Do you get 12V to the coils with the ignition on?
Old Oct 24, 2013 | 04:54 PM
Didn't see an answer to this
Old Oct 26, 2013 | 10:49 AM
I don't own a code reader and have no way of driving it anywhere since it won't start, therefor I have no way of knowing if it has an engine code or not.
Old Oct 26, 2013 | 12:16 PM
Well you need to get the codes read. Find a friend that has one. Find someone with the Torque App for their smart phone and the OBDII Bluetooth thing for it. You need to read the codes, that is a VITAL part of diagnosing this problem. Without reading codes you are just shooting fish in the dark.
Old Oct 26, 2013 | 12:52 PM
Someone else had asked if it was receiving 12vdc to the coil packs and indeed it is. I also have a Sentra and swapped the coil packs and plugs to it and they do spark in it. I'll ask around and see if anyone has a code reader.
Old Oct 28, 2013 | 07:34 AM
Gemner's Avatar
you can read the codes out without a code reader
1) Sit in the driver's seat.
2) Turn the ignition key to the ON position and wait three seconds. (Do not start the car.)
3) Rapidly depress and release the accelerator pedal 5 times in less than 3 seconds.
4) Wait 7 seconds. Push the pedal all the way down for ten seconds until the SES light flashes.
5) Release the pedal and start counting flashes to obtain the four-digit trouble code.
The SES light either flashes quickly or slowly, 10 slow blinks basically means prepare to read the code, then it will blink quickly to read out the first number of the code, pause, then begin blinking quickly to read out the next number (this happens up to 4 times), 10 quick blinks is a 0.
Its pretty obvious once you get it going what the flashes mean.
(I cant believe it took 2 days for someone to tell you that, you slacking maxima.org)
Old Oct 28, 2013 | 06:54 PM
2 codes;
P1610
P1612
Old Oct 28, 2013 | 06:55 PM
Thank you Gemner!!!
Old Oct 28, 2013 | 07:15 PM
Both point to NATS immobilizer. Guess that means a trip to dealership anyhow.
Old Nov 11, 2013 | 04:55 PM
I don't feel so bad now. Been at the Nissan Dealership since my last post and they can't figure it out either. Key replacement: $150, immo unit $???.??, master entry unit $612.??, and still won't start.
Old Nov 26, 2013 | 07:12 PM
Anyone need a 2002 Maxima that won't start? This one's headed for the crusher.
Old Nov 27, 2013 | 08:24 AM
Gemner's Avatar
no but if its a 6 spd Ill take your passenger axle
Old Jan 19, 2014 | 11:10 AM
Anyone else have any other ideas? I don't have thousands of dollars to spend on the car but would like to fix it. Sorry Gemner it's an auto. I wonder if an auto start bypass module would work?
Old Jan 19, 2014 | 11:33 AM
ac max 92's Avatar
Did you replace the battery yet?? Another thing to check is to see if the cylinders were flooded after cranking so much and depressing the accelerator so try pulling the plugs and see if they're wet. If so dry them up and pull the fuel pump relay and crank it a few times to get excess gas out of the cylinders then put the relay back, plugs back and crank it over but it sounds like the battery is pooched if the car started and ran fine before it sat i don't see why it would be a sensor.
