Ignition timing question
Old Sep 24, 2013 | 06:51 AM
88gtu's Avatar
I have a 2000 SE 5 speed that i bought with a blown tranny. I bought a used one from a junkyard and installed it. When the tranny was out of the car i pulled the flywheel off because i was going to do a 6 speed swap. When i put the flywheel back on i remember being able to turn it as it sat on the crank which tells me the dowel pin probably fell out while the flywheel was off. it is back together now and running but there are a few problems. When i start it it will start funny and sometimes sound like its hydrolocking. When it does start like that it will blow a nice puff of white smoke when it starts. It is acting like there is way too much timing. Im thinking the flywheel is in the wrong position. Yesterday i borrowed my friends scanner so i could see what the timing was doing and i took this video. Any input? I just wanna make sure thats what it is before i go taking the tranny off again. How the video got uploaded upside down, i have no idea.
http://www.youtube.com/watch?v=Ot9I-...ature=youtu.be
Old Sep 24, 2013 | 08:15 AM
knight_yyz's Avatar
Toolie
Timing at idle should be 15 +/- 5
Old Sep 25, 2013 | 05:26 PM
88gtu's Avatar
But should the timing advance like it does in the video? It is 5 at idle and as soon as it comes off of idle it jumps up to 46 - 48 degrees. Thats one hell of a vicious timing curve.
Old Sep 25, 2013 | 05:43 PM
Gemner's Avatar
if the flywheel is off, then the timing reading will not be accurate. I'm surprised it would run though, how many bolts are in the flywheel? I would think something like 8 which would mean off by one is still over 40 degrees off. If you aren't getting a check engine light its probably something else.
edit: I missed 88gtu's post somehow. The ecu is capable of determining timing from the cam sensors IIRC so since its reading over 40 it would make sense possibly that its using the cps which is reading wrong (5 degrees, actually 40 something) and as soon as the throttle moves it corrects using cam sensor info. Just spitballing, too bad its a PITA to physically check if the dowel is correct or not
Old Sep 25, 2013 | 05:44 PM
Brudface's Avatar
Timing shouldn't be at 5 at idle to begin with... Should be at 15 as Knight said, +/- 2 degrees in reality. Anything more or less and you have an issue somewhere.
Old Sep 25, 2013 | 05:54 PM
88gtu's Avatar
It did finally throw a few codes yesterday.
P0505 "Idle Control System Malfunction"
p0134 "No O2S activity Bank 1"
P1130 "Undocumented code"
Old Sep 25, 2013 | 11:34 PM
Gemner's Avatar
check the fsm for that last code
Old Sep 26, 2013 | 05:22 AM
D.Stillwell's Avatar
Initial timing advance (idle timing) should always be 15 +/- 2* (whatever yours is set to) and it should never change. Timing should only advance/retard under load, but initial timing should always read the same number no matter what.
You 100% have a problem if your initial timing is at 5* and that is definitely why your engine starts funny. Remember, initial timing advance correlates directly to crank position, you're lucky the car even started at 5 degrees, that's way too low for a Maxima.
Old Sep 26, 2013 | 09:56 AM
NmexMAX's Avatar
dot dot dot ...
Get the timing under load (WOT) from as low in the RPM to as high, that' the real timing (dynamic) curve. Also, see what it (timing) is along with idle when fully armed up. Mine was at 12º not too long ago, not sure why.
In any case mine always hovers in the mid to upper 40s when cruising under little to no load so that's at least normal.
tsi6001
Oct 3, 2022 10:23 PM
trasmadean
Jan 20, 2018 05:05 AM
max_speed97
Aug 26, 2015 07:46 PM
ZerotoSixty
Aug 6, 2015 04:34 AM
maxima297
Aug 3, 2015 12:50 PM
