Ordered Headers.... Is this all I need for easy install?
Old Sep 27, 2013 | 12:25 AM
george__'s Avatar
Lower oil pan from the Gen 4 Maxima x 1
14035-4W015 x 1
20692-65J00 x 1
Anything else I need?
shop is going to deal with extending the rear/front O2 (both rear are brand new, front are who knows)
thanks
Old Sep 27, 2013 | 09:13 AM
NmexMAX's Avatar
dot dot dot ...
Before extending the O2 sensor wires, take close look at the actual harness, and see if you can cut some of the wire loom tape and not have to extend them. Extending the O2 signal wire isn't a good idea IMO. They will also need to tap into the headers, or pipe post cat.
These are minor issues though.
Old Sep 27, 2013 | 09:32 AM
george__'s Avatar
Buying headers is so freaken time confusing **#*#
Old Sep 27, 2013 | 09:47 AM
Prophecy99's Avatar
from what I know there is nothing easy about a header install.
Old Sep 27, 2013 | 10:03 AM
george__'s Avatar
I meant "relitavely" speaking ><
I took a peak under the car today and no way I am going to try this myself. SO much rust under there I think the shop will have to use screw extractor kits everywhere.
Old Sep 27, 2013 | 10:44 AM
ateick's Avatar
Did you order headers George??? You have another post going simultaneously for a group buy on OBX where you don't seem to have anything ordered yet.
Old Sep 27, 2013 | 10:47 AM
george__'s Avatar
I'm in the middle of ordering Cattman AND OBX headers.
Old Sep 27, 2013 | 11:23 AM
NmexMAX's Avatar
dot dot dot ...
It was easy 10 years ago, as these cars age and rust, it get's more and more difficult. When I installed headers back on NYE 2004/2005, with 2 years on the clock and 37k, I probably could have eaten using my best China while doing it. Now, I barely tap something under there and I feel as if I've been sandblasted.
Old Sep 27, 2013 | 05:47 PM
TriniSpeC's Avatar
why the oil pan? I second cutting the o2 sensor harness, that wiring in there is hard to solder.
Old Sep 27, 2013 | 07:36 PM
george__'s Avatar
I bought the three parts + some nuts and screws locally today and the total came out to $300 after tax
Old Sep 27, 2013 | 09:44 PM
02whitemaximase's Avatar
Yeah, why the oil pan?
Old Sep 27, 2013 | 10:16 PM
Chris Gregg's Avatar
Get Off My Lawn
I recommend the 4th gen oil pan after reading old threads about members installing it to make future oil changes easier with the Cattman y-pipe. The Cattman Y just runs too close to the oil drain plug. You have to use a wrench to remove the plug its so tight. The 4th gen lower pan drains the oil toward the passenger side; no obstructions and no oil on the exhaust!
Don't get me wrong, changing the oil using the stock pan isn't horrible, but I wish I would had spent that extra $30 or so odd dollars on a new pan while I was in there. Worth it in conveiniance.
Old Sep 28, 2013 | 03:21 AM
george__'s Avatar
The car doesn't have anything fancy exhaust wise... Just a little noisy but no mandrel bends and it sounds a little fart wagon(ish)
Old Sep 28, 2013 | 11:57 AM
ateick's Avatar
Wtf George? You have two sets of headers coming - OBX and Cattman? And you just spent $300 on an oil pan, manifold gaskets and some nuts and bolts?
I see things haven't changed.
Old Sep 28, 2013 | 12:20 PM
george__'s Avatar
Won't be hard to sell the OBX stuff and I'll be doing someone in Canada a favour bringing it into Canada
Any news on TMEC?
PH98I30
29
Feb 10, 2025 12:03 PM
adamgalazka
Feb 5, 2023 08:24 AM
9aj9
Apr 5, 2020 12:11 AM
MaxLife17
Jun 27, 2019 01:37 PM
jds22
Sep 4, 2015 01:52 PM
