2001 maxima running on 4 cylinders
Old Oct 3, 2013 | 06:43 AM
squack10's Avatar
Hey guys,
I'm working on a 2001 Maxima for a friend. He brought it to me because it is running rough and is down on power. I discovered that two of the cylinders in the rear bank are not getting spark by unplugging the coil packs one by one and looking for a change in rpm. Two of the rear coil packs made no change in how it ran so I replaced them. While I was in there, I changed spark plugs and those two were saturated with gasoline so I know there is fuel. Got her all buttoned up, stared up, no change. Did the unplug thing again, still missing those 2 cylinders.........
I don't know what to do next, any advice? I read a lot about coil packs going out so I thought I was on the money. Do these things have an ignition module that goes out? or is there a way to test the coil packs?
Any help is greatly appreciated!
Old Oct 3, 2013 | 06:48 AM
bennuss's Avatar
yes test them by testing the resistance (search on here for how) or better - swap them with another coil in the same bank and see if the non sparking cylinder changes
Old Oct 3, 2013 | 06:52 AM
squack10's Avatar
ok I will do that this evening after work. Thanks.
Old Oct 3, 2013 | 07:07 AM
TDotMax's Avatar
If its the coil pack ONLY replace with OEM. I learned the hard way due waiting on dealership to get stock. I used aftermarket and it misfired until car warmed up.
Old Oct 3, 2013 | 07:37 AM
squack10's Avatar
Dammit. Ok I got the replacements at NAPA. I'll try swapping the known good rear coil and see what gives.
Old Oct 3, 2013 | 09:18 AM
bennuss's Avatar
some of the ones being sold by the local stores are oem repackaged. advance auto rear coils are oem hitachi (at least they were a few months back) the front ones are not they aare made in poland. also I believe beck/arnley are repackaged oem from japan.
Old Oct 3, 2013 | 09:59 AM
TDotMax's Avatar
Napa is what I bought and misfired and cold starts. Returned it when my OEM came in and no issues.
Old Oct 10, 2013 | 05:53 AM
squack10's Avatar
well I've ruled out the coil packs.... I swapped the known good one for a suspected faulty one and no change. pulled the plug and it was SOAKED in gasoline. I started the car with the pack out with a spark plug and it is working. I went ahead and pulled the plenum, the injector on that cyl is wet with gas on the outside? I pulled all six, going to take them in for a clean and test. Am I on the right track?
Old Oct 10, 2013 | 11:18 AM
squack10's Avatar
well just heard from Napa, 2 injectors failed! I'll have new ones in the morning, hopefully it will be the end of this issue!
Old Oct 11, 2013 | 07:05 PM
squack10's Avatar
Well FML. Still runs like poo. I did notice quite a bit of oily residue in the intake, and a little on the MAF. Can you clean a MAF without damaging it?
Old Oct 12, 2013 | 12:50 PM
ZWCMax's Avatar
Get a can of CRC MAF cleaner...should do the trick for that..could the cylinders have lost compression?
Old Oct 14, 2013 | 12:14 PM
squack10's Avatar
Grabbed the MAF cleaner, tried that. Didn't work. I told the owner of the car he's probably better off taking it to a real mechanic as I don't have time/ patience for this right now. Judging by the blowby that's evident in the intake, this motor may need to be rebuilt, which sucks, he paid a couple grand to have it installed when the original one went.
Old Oct 14, 2013 | 12:42 PM
Gemner's Avatar
Blow by and oil collection in the manifold is normal. Have you checked the replacement coils for spark? If the coils have been replaced but still arent sparking, and a known good coil does not produce spark when swapped, you need to check for voltage at the coil. If you have a somewhat good voltmeter you can probe the connector and watch for the signal from the ECU. If the coils arent getting a signal you wont have any spark, if there is no signal you either have fried coil drivers on the ECU or a wiring issue.
ah2002
Mar 9, 2016 01:42 PM
District
Aug 15, 2015 08:23 PM
acw
Aug 13, 2015 12:50 AM
Bruceharrison
Aug 9, 2015 07:56 AM
wpr
Aug 5, 2015 03:28 AM
