Dim Headlight
Dim Headlight
I got a 2000 maxima GLE, My car was in a accident there was front end damage. The autobody shop repaired the damage, but the passenger side headlight is dimmer then the drivers side headlight. They had to replace the passenger side headlight cause thats were I was hit. Is there something they miss or didnt hook up correctly..
Well, if it's a brand new headlight and it's dimmer than the older one I'd say yeah there's something wrong.
Could be wiring. But check the bulbs in the original vs. the new one because a replacement headlight probably came with some crappy bulbs.
Swap the bulbs as TallTom advised. Also double check that the bulb is type 9003.
And very important - do not touch the glass part of the bulb. The oils in you skin will make the glass crack. Clean it very good if you touched it.
doctorpullit
Oct 28, 2019 10:58 PM
Dennis Twohy
Oct 1, 2015 06:01 PM
