2001 Maxima worth fixing?
Old Oct 28, 2013 | 01:27 PM
titus12's Avatar
Hello,
Been looking at the forums and different guides and trying to figure out if my car is worth fixing.
I have gotten two p430 codes over the last year.
The engine seems to pause them jump forward at times when going at slower speeds (5-10mph).
Been told all four struts are bad and tires are going with the struts.
A leak in the AC Compressor.
Also it will idle super rough sometimes right after being started but goes away after being driven for a bit.
I assume the catalytic converter is the p430 code which I was quoted about 900 to have fixed. The struts I was quoted about $1500 to have fixed and $900 for the AC. Then some set of tires on top of all of that after that.
My question is my 2001 Maxima with 145k miles and close to $3,500 in repairs plus tires worth fixing?
I can't do any work on my own because the only place I can park the car is on the street and the most mechanical thing I have ever done is change the oil. I am concerned that the catalytic converter might have damaged the car. I have had to replace the radiator already as well.
Old Oct 28, 2013 | 01:42 PM
Thaboywonder6588's Avatar
Originally Posted by titus12
Hello,
You Can Definitely Do Better Than 1500 For Struts...I Got H&R Springs And KYB Struts For 550... PM Djfrestyl About Installation... He Has A Forum On Here And The Guy Knows His Stuff
Old Oct 28, 2013 | 02:15 PM
NmexMAX's Avatar
dot dot dot ...
Those prices are outrageous. You can do better and it will last a long time and pay itself off.
Old Oct 28, 2013 | 02:24 PM
titus12's Avatar
If you can recommend any shops near Seattle that would be helpful. I would rather not do this sort of work on my own. I have no where to do the work since the car is always just parked a street that's reasonably busy and it's my only car so I can't easily get to a shop if something goes wrong.
Old Oct 28, 2013 | 02:43 PM
NmexMAX's Avatar
dot dot dot ...
http://forums.maxima.org/west-coast-13/
Old Oct 28, 2013 | 03:04 PM
george__'s Avatar
too much to fix
time to move on
Old Oct 28, 2013 | 03:43 PM
Maverick4189's Avatar
Fix it. Way cheaper then you are making it out to a bro, do your homework and it will all work out. I've dumped thousands into my car for repairs an mods. And I will continue to to that. One thing about building it from broken is it's done better then factory and how you want it.
District
Aug 15, 2015 08:23 PM
Balkins
Aug 12, 2015 06:39 AM
kirkhilles
Aug 8, 2015 10:53 AM
wpr
Aug 5, 2015 03:28 AM
