P0430 replace pre-cat or install main cat
Old Oct 28, 2013 | 03:39 PM
imonlybonnie's Avatar
I've been having this code for a few months now. I took it to the exhaust 10/26/2013. When I took it to shop the owner said that i didn't have a main cat and showed me.
the code description
Trouble Code: P0430
Catalyst Efficiency Below Normal (Bank 2)
Possible Causes:
Air leaks at the exhaust manifold or in the exhaust pipes
Catalytic converter is damaged, contaminated or has failed
Front HO2S or rear HO2S is contaminated with fuel or moisture
Front HO2S and/or the rear HO2S is loose in the mounting hole
Front HO2S older (aged) than the rear HO2S (HO2S is lazy)
do you guys think me installing the main cat will erase the code or do you think installing the pre-cat for bank 2 will fix the code. I need to get rid of the code to get my car inspected.
Old Oct 28, 2013 | 04:14 PM
memphisballer's Avatar
Hello and welcome.Can you pass emissions with no main cat??Anyway you need a Bank 2 cat plain an simple.I just resolved this issue by removing it,gutting it and putting sparkplug
nonfoulers on the O2 sensor.This is hands down the cheapest fix there is and you wont have to worry about this code ever granted the O2 sensor is still good.
Old Oct 28, 2013 | 04:19 PM
How did you gut it? And where can I get the nonfuelers?
Old Oct 28, 2013 | 04:22 PM
DjHackStyle's Avatar
You dont need a main cat to pass emissions if theyre using an obd2 test. Only ur precats are monitored by o2 sensors, those will give u a check engine light and fail emissions. If the precats have failed they can be gutted out and u can install o2 spacers or sparkplug anti foulers in order to still pass emissions.
Old Oct 28, 2013 | 04:27 PM
just remove it and take the tool of your choice and beat the crap out.Check this thread below
http://forums.maxima.org/5th-generat...t-problem.html
Old Oct 30, 2013 | 03:44 PM
nestorlugo's Avatar
Op.listen to Djhackstyle if or is your fed spec like me just change your oem y pipe,Name:  CAM01111_zpsf842e01d.jpg
Old Oct 31, 2013 | 09:38 AM
bennuss's Avatar
Swapped my upstream o2s with new denso ones and my p0430 cleared.
VQ'ed
69
Aug 27, 2020 12:29 PM
vanebecker
Aug 23, 2015 07:40 PM
maxinout93
Aug 20, 2015 02:17 AM
kirkhilles
Aug 8, 2015 10:53 AM
1992maximase30
Aug 5, 2015 09:27 PM
