PITFA MM bolt
Old Nov 13, 2013 | 05:40 PM
ACee's Avatar
See photo...
Definition of PITA.
Guess I will be recip.sawing it.
Old Nov 13, 2013 | 06:27 PM
MrEous's Avatar
^ Jeff™
Sorry but that pic is so washed out my eyes are bleeding...lol
Which bolt?
Old Nov 14, 2013 | 04:53 AM
ACee's Avatar
Old Nov 14, 2013 | 05:48 AM
TallTom's Avatar
Stupid idea, but can you just clamp it with some big vice grips from above and remove the nut from below with a socket and some extensions?
Old Nov 14, 2013 | 06:52 AM
NmexMAX's Avatar
dot dot dot ...
Ahh, the side mounts.
Yeah, I haven't touched those.
Old Nov 14, 2013 | 07:58 AM
Gemner's Avatar
why are you going there anyway? If youre pulling the motor you dont need to go there and if youre trying to get to the precats you dont need to go there
Old Nov 14, 2013 | 09:17 AM
NmexMAX's Avatar
dot dot dot ...
Yeah, a little background would help.
Old Nov 14, 2013 | 09:27 AM
nismopc's Avatar
That bolt is not loose in the mount. It is secure and doesn't turn.
Appears from the pictures, he stripped the **** out of the nut. So I am assuming w/o any details from poster that he was attempting to drill out the head of the bolt and then replace with a actual nut/bolt combo.
Just my assumption...
Old Nov 14, 2013 | 09:43 AM
rkspec's Avatar
what part are you removing?
Old Nov 14, 2013 | 05:31 PM
ACee's Avatar
I finally got the right mount out. All but that one bolt that passes through the block closest to the radiator came out easily. It took me using a cutting wheel that was mostly used up and small enough to get in there to remove the pitfa bolt. Ended up punching it down through the top where it looked like I had been drilling at it. But I got it!
Photos to follow.
Old Nov 14, 2013 | 05:32 PM
ACee's Avatar
Air powered cutting wheel btw.
Old Nov 14, 2013 | 05:53 PM
ACee's Avatar
http://rs993.pbsrc.com/albums/af58/a...73.jpg~320x480
http://rs993.pbsrc.com/albums/af58/a...0?t=1384479784
http://rs993.pbsrc.com/albums/af58/a...0?t=1384479834
http://rs993.pbsrc.com/albums/af58/a...0?t=1384479931
http://rs993.pbsrc.com/albums/af58/a...0?t=1384479955
I would have cleaned the engine compartment when I had the old out but I was ready to get the new one installed.
No more thumppop in passenger front now.
Old Nov 14, 2013 | 05:54 PM
ACee's Avatar
Originally Posted by nismopc
that bolt is not loose in the mount. It is secure and doesn't turn.
Appears from the pictures, he stripped the **** out of the nut. So i am assuming w/o any details from poster that he was attempting to drill out the head of the bolt and then replace with a actual nut/bolt combo.
Just my assumption... :d
10-4
Old Nov 14, 2013 | 06:08 PM
ACee's Avatar
Here's the old front mm I replaced a week ago...
http://rs993.pbsrc.com/albums/af58/a...0?t=1384481125
Not a PITA.
Old Nov 17, 2013 | 08:32 PM
CMax03's Avatar
How did you windup stripping that nut? I removed/replaced so many right mounts I don't know how you stripped the nut like that!!!!
Old Nov 18, 2013 | 10:29 AM
ACee's Avatar
It was on really really tight and I should have used a 6 point socket.
Just lucky I guess....
litch
123
Jan 4, 2024 07:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
