HELP!!! 03 maxima sounds like an 83 diesel mercedes!
Old Dec 1, 2013 | 04:32 PM
blackbeasst's Avatar
noticed when the car sits for days at a time when i crank it back up i get some funky stuff going on.
2 codes being thrown are p0011 and p03061, which i see the latter is a misfire in #6.
i took it for a drive and couldn't get past 25-30mph im guessing due to the misfire.
here's a vid after it warmed up and after the drive
Old Dec 1, 2013 | 04:42 PM
blktalon456's Avatar
That sounds like lack of oil. Not to sound crazy but is the oil full????
Old Dec 1, 2013 | 06:30 PM
ha! yeah i thought the same thing and did in fact check just to make sure
Old Dec 1, 2013 | 07:16 PM
JohnVQ30's Avatar
When my Alternator was going bad it sounded exactly like that,i used a really long screw driver to check where the sound was coming from,and it was the alternator.
Old Dec 2, 2013 | 10:52 AM
would that make the car feel like it was neutered and have a lot of power loss?
Old Dec 2, 2013 | 11:27 AM
Gemner's Avatar
exhaust leak would
the code is for IVT control, maybe you skipped a tooth on the timing gear, that would definitely get you poor power as well
Old Dec 2, 2013 | 12:19 PM
Originally Posted by Gemner
exhaust leak would
not sure i've ever touched the timing gear
Old Dec 2, 2013 | 12:42 PM
Gemner's Avatar
im sure you havent. Its not exposed like on some other engines. The chain can skip a tooth if the tensioner loses oil pressure or if the chain guide wears out and the tensioner cant keep enough tension in the chain
Old Dec 2, 2013 | 12:55 PM
sounds like a barrel full of monkeys kinda fun to fix
maxinout93
Oct 27, 2015 01:29 PM
Mcnabb34
Aug 11, 2015 08:45 PM
MikesChevelle
Aug 9, 2015 11:50 AM
follyburr
Aug 7, 2015 09:50 PM
Jcof88
Aug 3, 2015 10:43 PM
