OBX Headers & CAT Back System
I resently installed the complete OBX set mius the rear CAT Delete Test Pipe. I have an empty rear CAT now. I'm thinking that the Cabin noise would go down if I replace the empty CAT with either the OBX CAT Delete
or a MagnaFlow Direct Fit CAT. Oh and I already installed Dynomat in the cabin. If I go with the MagnaFlow CAT it might look better on emissions day too! Has anyone have any thoughts on this?
The OBX CAT Back came with the large resonator included. I had the CAT Back first then resently installed the Headers and empted the CAT because the insides were falling apart. I believe that the Tinney sound is from the empty rear CAT.
Hmm I posted a similar question about a month ago. Basically the answer was you could add sound dampening material inside your trunk and car to reduce cabin noise and add a bigger resonator to quiet the car down
I installed Dynomat on the floor boards and trunk when I installed the OBX Cat back and it came with a resonator. Then sound was good inside. Once I added the OBX Headers and empty cat it got way loader. Guess I need to just turn the music up!
Did you check for any leaks? Sometimes air leaks can cause massive loud car
Call Warpspeed and get yourself a flanged Hi flow (Ceramic Cat) for about $100- $125 and Full Metallic substrate (Metallic core) for $189.....
I would like some pictures of this OBX but I found it!
Invest into a larger resonator first even the 4" round Magnaflow are awesome and I've equipped 4 cars with them and the sound quality was improved! Good Luck pm me if you need so ideas!
Ive used the magnaflow resonators. I bought the longest one I could in a 4 inch case. Welded it in place of the old resonator, it really helped especially with drone. This is the one I bought I think http://www.summitracing.com/parts/mpe-10436/overview/
Another remedy would be to install a 5" x 8" x 22" Magnaflow!
Look here
http://forums.maxima.org/5th-generat...ng-thread.html
You really dont need a "tune" with just an exhaust system upgrade,it when you start fooling with the air/fuel system ie: intake,injectors,throttle body,manifold spacers.
So once again please dont take advise from the above^^!!!!
@OP - don't listen to The_Fixer
George wtf do you need to tune for a exhaust upgrade.its a exhaust the only thing you need to worry about is getting 02 sensors relocated or sims installed the exhaust dont effect your A/F or timing unless theres no 02's in the system to tell if your running rich/lean ffs learn something!!!
I've said it before: Cars are not your thing.
I think I speak for everyone when I say stick to asking questions and stop trying to give advise.
Your only advise is what you've heard from us here, some of it could be wrong depending on who was having a bad day.
So stop commenting like you know when you just kinda learned from someone else the day before.
Leave the answers up to the more experienced members FFS.
according to op, headers and exhaust
Dude get a damn bicycle a single speed one at that because you don't even need gears anyway sense you drive a automatic around in 3 all the time!
Not all the time. City driving + good weather it occasionally gets driven in 3.
hot04
Aug 24, 2015 07:07 AM
sonic7
Aug 20, 2015 12:23 PM
MikesChevelle
Aug 19, 2015 07:19 AM
