18x9.5", RPF1's Fitment question.
I am eventually going to get a set of enkei rpf1s to put on the max. Has ANYONE put 18x9.5 wheels on a 5.5 that is a member here? just trying to sort out fitment issues if any before i go spending $1500.
+15 is low... Is your car lowered or are you going to lower it? +15 if you lower it you are going to need a fender roll more than likely, unless you stretch the tires on there. if you run like a 245ish or larger tire it will rub.
i don't want the wheels to stick out up by the fender at all. I want them to be barely in enough to where they will tuck if i go over a big bump. I will probably get some tein coilovers but im not going to have it slammed. Just low enough so the wheel well doesn't have more than an inch or so gap all the way around.
+20 or +25 is to low of an offset. Like I said it will also depend on the tire you choose to run as well. If you are worried about hitting the wheel well, go with a higher offset. I will be running 235 35 19 on my 19" Rays they are +30 front at 8" and +33 rear at 8.5" and I know they are going to be very close to wheel well. Running +20 on 9.5" is going to be around the same unless you run like a 225 tire (which will stretch it) If you are going to run a 245 or bigger you are definitely going to rub.
This is 18x8 +30 front with a 225 45 tire. As I read it you don't want to have it this close.
I"ll do the testing to fit these:
Umm I hate to bust your ego back but they are 18x8 They are NOT 05+ Maxi wheels, they are 350Z wheels
http://www.350z-tech.com/wiki/index....Specifications
And if you actually read all the post on this thread you would have read that I have own 5 or 6 sets of these specific wheels, and like most can read up to and including 4 digits in a row. 18x8 somehow does not equal 18x7.5
I don't rock those wheels anymore... I have 19" Forged RAYS that are 21 and 19lbs... but really I don't care about the weight. I am not tracking my car, and it goes fast enough for a front wheel drive car.
That is actually almost exactly how i want them to fit in the front and rear. The rear will probably be 9.75 inches wide actually (thinking of just going with some XXRs instead of giving my arm and leg away for the RPF1s). i will probably run a 255 tire in the rear and a 225 up front. I can roll the rear fenders if necessary, but i will probably just try to find a pretty high offset if possible (+44)
running a high offset (+44) should be perfect. probably wont need a roll... and if you do, it will be slight
pears
Sep 18, 2015 05:25 AM
