Any Help Appreciated (Newbie)
I have a 02 Maxima that has been acting up, for a while now when I crank it up it, it tries to cut off it wasn't bad to start but now it almost cuts off completely but bounces right back & drives, so about 3 weeks ago I got the p0011 code which is cam sensor related, I also had some stalling for a few minutes it would jerk like crazy when I pressed the gas pedal & when let off to coast it runs fine & a belt squeals but come back after a few minutes like nothing was wrong, so I replaced the cam solenoid & sensor associated with bank 1 & the code went away but still get the intermittent stalling & what I call hard starting issue & the whole time the motor never cuts off like its an electronic issue, I also get the battery light & brake light when it stalls but at the same time I can not press the gas pedal but after I cut off & crank back up its fine like nothing was ever wrong, & I've seen where people say that when the battery & brake light come it the alternator but nothing about the pedal cant be pressed while on anyways any info would be appreciated & I think I covered everything but thanks in advance
REDinLV
Aug 15, 2024 12:30 AM
