Gauges Died
Gauges Died
The other day i stopped and topped off my fuel, next day i go to start the car and i notice the fuel light is on, thinking i had a leak i looked, nothing, Then i noticed none of the gauges where working, fuel on E, temp on cold, RPM needle barely bouncing and the speedo barely hits 10mph & my milage is all scrambled........then i got a code for a speed sensor, ok no prob, my question is, will a bad sensor cause all these issues and will the go away once i replace the sensor ?
Well today i was taking my girl to work and the headlights shut off, the radio went out, turns out the alternator died, I am wondering if that had a cause in the gauges not working properly., Got a new one coming monday. hope it fixes everything.
Turns out the alternator was fine, since it is not a self exciting alternator it relies on a signal from the cluster with the light to tell it to start charging basicly, since i had the cluster removed the alt did not go into charge mode because it was not getting the signal . put cluster back in, its fine, except my gauges still dont work.
maxima297
Sep 30, 2015 03:32 PM
220k+ A32
18
Sep 22, 2015 11:39 AM
RWCreative
Sep 21, 2015 11:01 AM
