Help decribing this problem.
Old Jan 31, 2014 | 07:28 PM
ab16's Avatar
I recently noticed a problem with my 5.5 gen max. A couple days ago when I pulled up to a Red light my engine began to shake. I then began to start driving and the shaking still continued. My service engine soon light began to blink so I stopped by the side of the road. The shaking stopped and I was able to continue driving like nothing happened. I'm not sure if this has anything to do with the idle or not.
Old Jan 31, 2014 | 08:47 PM
CauzinDrama's Avatar
Not sure what caused it but that's a misfire. Might have a coil or injector going bad.
Old Jan 31, 2014 | 09:03 PM
4th gen maxi's Avatar
Mos deff. Injectors
Most likely dirt or debri.
Harder to find source cause its not an electric fault.
Have you removed your fuel rail recently?
Old Feb 1, 2014 | 08:16 AM
ab16's Avatar
Sorry, I don't really know a lot about cars. I'm still learning but I'll see if I can take it to my mechanic and see what he says.
Old Feb 1, 2014 | 12:42 PM
mclasser's Avatar
If it is a fuel-related issue, try pouring a bottle of Techron Concentrate Plus into your gas tank. Even if it doesn't work, it won't harm anything either.
Old Feb 2, 2014 | 09:16 PM
gapboi210's Avatar
There is a check engine light for a reason. It should of stored a misfire code in the history. You need to get that scanned first. Everything else such as replace this, do that is just a shot in the dark.
Old Feb 5, 2014 | 10:07 PM
colt149's Avatar
Help Describing this problem
The first thing to do is to hook up your vehicle to OBD Scan tool to determine the exact code error. I had a check engine light two days ago, I scanned it with my OBD, showed P00021 (Camshaft Position Timing Advanced Bank 2). I replaced the Camshaft Position Sensor on Bank 2 and the problem was solved. I advised you not to use any fuel additive or cleaner, even Nissan Owners Manual stated not to use any cleaner, beside 5th generation started to using electronic throttle.
Old Feb 6, 2014 | 07:09 AM
NmexMAX's Avatar
dot dot dot ...
Blinking SES = misfire = bad coil or plug. Injectors are rare that they die. My 4th gen has its original injectors, and they have yet to go away.
jmlee44
Oct 2, 2022 02:13 PM
D Mason
Jun 21, 2016 04:43 AM
Unclejunebug
Apr 2, 2016 05:42 AM
Noela
Sep 26, 2015 08:22 AM
markevans999
Sep 10, 2015 04:29 PM
