2002 maxima light
Old Feb 15, 2014 | 07:17 AM
gregl1's Avatar
2002 maxima light
Every time I turn on the headlights the interior clock light dims to the point it can barely be seen ???
Old Feb 15, 2014 | 12:45 PM
george__'s Avatar
Any weird noises?
Just a few weeks ago I was having flickering lights, car having hard time starting etc etc and then the alternator related components seized and blew up
Old Feb 15, 2014 | 01:10 PM
DennisMik's Avatar
The clock is part of the dash light system that are dimable. Are the lights for the speedo and other gauges ok? If the other lights are ok, then maybe the clock is developing cold solder connections.
Old Feb 15, 2014 | 03:15 PM
Fatboy98maxima's Avatar
they go dim on my 2002 GLE also but not to the point of not barly not seeing them
Old Feb 15, 2014 | 04:58 PM
TallTom's Avatar
Totaly normal. It's tied in with the dimmer switch too.
Old Feb 15, 2014 | 05:27 PM
King_Ten_Ahead's Avatar
Its normal. It dims it when the lights are on so its more pleasant to look at in the dark. But it sucks when you have the lights on when its light out. Im pretty sure theres a thread showing how to make it bright all the time. . I think it involves cutting wires
Old Feb 17, 2014 | 11:58 PM
venturous's Avatar
You should have a roller down near the steering column that will cause the dash lights to be bright when you want them. I have an I35 and I wish my lights on the console with the controls and radio would not dim so much when I get the gage cluster where I want it. They are about right with the dash lights maxed, but the cluster is too bright.
Old Feb 18, 2014 | 07:29 AM
Amerikaner83's Avatar
It's as stated above - if the dimmer is all the way up and it's still very faint, it's the clock going out due to cold solder connections. Remove it, resolder any cold joints, and reinstall. Easy peasy
or even easier, perform the "always bright" mod (it's the RED wire with the BLUE TRACER that you cut)
Old Mar 17, 2014 | 12:34 PM
DjHackStyle's Avatar
Just did this and it worked, so far so good its the red wire with blue tracer and it has silver dashes on it in my 2003
fastcarny
May 18, 2020 10:40 AM
fastcarny
Aug 12, 2015 03:50 PM
papo99
Aug 9, 2015 07:24 AM
yat70458
Aug 3, 2015 01:16 PM
