no power when key turned
Old Feb 17, 2014 | 04:17 PM
fzndz4life's Avatar
2000 Maxima new starter new battery new MAF ran good for 2 days turned off at store now won't start no dash lights radio nothing all under hood fuses good any suggestions??? (besides burning it)
Old Feb 17, 2014 | 04:22 PM
King_Ten_Ahead's Avatar
Bad connections to the battery possibly. I would think that if it were the alternator itd still have a little power. A little vague...
Old Feb 17, 2014 | 04:24 PM
colt149's Avatar
No power when key turned
Check the battery connection, retighten the positive and negative post
Check the fusible link box (positive side)
Read this link page 11
http://www.nicoclub.com/FSM/Maxima/2002/EL.pdf
Old Feb 17, 2014 | 05:27 PM
fzndz4life's Avatar
already checked battery connections, starter connections fusses under hood test good thinking ignition switch????
Old Feb 17, 2014 | 05:36 PM
4thGenTuner's Avatar
Kinda doubtful.
Since you just worked on the battery, starter, and whatever else I would go back over everything that has recently been disassembled.
Have you checked your battery while the car is off? What kind of voltage are you seeing? More than 12vdc? Less?
Do you have a Volt-ohm meter?
My guess is loose wiring, maybe battery terminal connections not making good contact. Also check the plug/terminals on the starter & alternator.
Old Feb 17, 2014 | 06:35 PM
DennisMik's Avatar
Is there anything that works? How about the dome lights, the horns - anything?
Check the battery voltage as suggested.
Double check the main fusible link on the battery cable, check the IGN SW fusible link in the fuse box by the battery with an ohmmeter.
Old Feb 17, 2014 | 08:17 PM
keon3030's Avatar
I had same issue with my car it was ignition fuse under hood is a 30 amp fuse my cold air intake was touching a wire on my starer
lowpost99
Oct 26, 2025 06:53 PM
LtLeary
Sep 14, 2015 12:33 PM
Pnjboyzz
Sep 4, 2015 09:04 AM
trungg86
Sep 4, 2015 04:58 AM
