Car cranks a lot before starting
Old Jan 5, 2015 | 04:02 PM
  #81
hgarcia's Avatar
When i let the pump prime it helps but it still cranks for a while before starting
Old Jan 5, 2015 | 04:06 PM
  #82
hgarcia's Avatar
Even though damper is not leaking should i still replace it or should i replace filter or spark plugs before that
Old Jan 12, 2015 | 04:38 AM
  #83
hgarcia's Avatar
Could the damper be bad even if its not leaking?
Old Jan 19, 2015 | 01:48 PM
  #84
hgarcia's Avatar
is there a fuel pump check valve?, when i put key in the on position it starts after the 2nd or 3rd crank.
Old Mar 14, 2015 | 06:28 PM
  #85
hgarcia's Avatar
everytime i try to figure this out its like something happens with the car and doesnt want to be fixed. rear main seal leak and crankshaft seal leak. but i did end up replacing control arms due to bushings saturated in oil, smoother ride now. replaced both inner and outer tie rod as well. got an alignment it was fine for a couple of weeks. now it keeps pulling to the left and the right. i did take it back and same thing fine for 2 weeks then pulling again, like its not holding the alignment. it does it when im going around like 30-40, i wanna figure that out before putting more money into it for the starting issue. any ideas?
Old Apr 24, 2015 | 06:59 PM
  #86
hgarcia's Avatar
ok so re focusing on starting issue, where is the vacuum line on both fuel presser regulators going, cause the damper has no vacuum and it looks like its going to some sensor. any ideas?
Old Apr 24, 2015 | 07:20 PM
  #87
cornholio's Avatar
Originally Posted by hgarcia
I forgot to add that a lot of the times if I leave the key in the on position it makes a noise and it starts up better/faster
That's what I thought but it's coming from engine bay
It's like a whirling noise that goes on for a few seconds
Another concern i have is that is that its very clunky when I go over bumps, it also seems to pull one way when we accelerate sometimes, any ideas?
not sure if you solved the noise or clunks/pulling issue but the whirring noise you hear might be your AT engine mounts. i know you've replaced some suspension parts but i'd think mounts could be a contribution to some clunking, possibly pulling? but not sure. if thats the case get manual mounts to replace the AT ones have been reported to damage ecm at a certain point
if you have a MT than that wouldn't apply lol
Old Apr 25, 2015 | 01:44 PM
  #88
hgarcia's Avatar
I did replace the mounts as well as disconnect the wires to them, it ended up being the mounts and the bearings in the struts, the struts were replaced but those weren't. but im not getting vacuum on fuel pressure damper from vacuum like, i dont htink its going to the right place. any ideas on where it goes?
Old Apr 25, 2015 | 06:04 PM
  #89
maxiiiboy's Avatar
This thread is too long and confusing. I you want help, start fresh by: a) Listing the problem(s) you have, b) List the CEL codes, if any, you are having; and c) You can also list all the parts you already replaced; also tell us whether they are OEM or after-market.
Old Apr 25, 2015 | 06:28 PM
  #90
hgarcia's Avatar
lol ok, so my only problem now are long crank before starting, ive replaced the regulator, starter, battery, added a ground wire, but what i noticed the other day is that i have no vacuum to the damper, the hose is just going to some sort of sensor is this right or does it belong somewhere else?
Old Apr 25, 2015 | 07:20 PM
  #91
maxiiiboy's Avatar
What/which hose? ..... I assume you are not taking about the AT breathing hose, right?
What "damper"?
What sensor?
Can you post pictures?
Old Apr 27, 2015 | 04:14 PM
  #92
hgarcia's Avatar
no the vacuum hose going into the fuel pressure regulator damper, it doesnt have any vacuum.
Old Apr 27, 2015 | 05:27 PM
  #93
Maximeltman's Avatar
Is the hose going to the map sensor? check the map sensor, it has three hose connections one of which iirc goes to the fuel damper. but i dont think thats your problem though. have you cleaned your crank/cam sensors yet?
Old Apr 28, 2015 | 12:49 PM
  #94
hgarcia's Avatar
yea its going to a split then the map sensor, and crank and cam sensors were already replaced.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Stagnet04
Aug 16, 2015 11:15 PM
halfpol
Aug 5, 2015 08:24 PM
