Maxima won't crank!! Help please!!!!
I have a 2K Maxima and it is having problems cranking! I am not sure what the problem could be seeing as how I have already put a new motor in it, it has a new starter, new battery, new plugs, new cam shaft and crank sensor, new oil sending unit. I just pulled the plugs out and they were all soaked with gas! All the coils are sparking but still has trouble cranking..If anyone can help it would be much apprciated...
Are you saying the starter is not cranking? If so, check out the starter (and battery voltage). However, it looks like the fuel pump and injectors are working since your plugs are wet ..... .
Post #7 on this thread
http://forums.maxima.org/5th-generat...halp-asap.html
has troubleshooting guide for this class of problems.
kjlouis
Nov 24, 2018 06:09 AM
BobMax
Aug 15, 2015 12:35 PM
