Homemade PCV oil catcher?
Old Feb 28, 2014 | 10:11 PM
car5car's Avatar
Any ideas?
Thanks.
Old Feb 28, 2014 | 10:39 PM
Fakie J Farkerton's Avatar
There are build your own threads on this from Home Depot parts, but the plastic ends up cracking after a few years.
Just get a Jegs one.
Lasts longer and works right out of the box.
Old Mar 1, 2014 | 10:29 AM
colt149's Avatar
Home made pcv oil catcher.
I made one, I used the aluminum water bottle with the smallest opening, you can buy it Kmart, Target. I drill two holes around 3 inches above the base, one inch apart (between the lower and upper hole) not large enough to place this two fitting ,sealed with oem Nissan liquid gasket
JEGS Performance Products 15973 Brass 90 degree Elbow Fitting : Amazon.com : Automotive JEGS Performance Products 15973 Brass 90 degree Elbow Fitting : Amazon.com : Automotive
Attached the PCV tubing from the PCV valve to the lower hole, then another PCV tubing from the upper hole to the intake. Use the PCV 3/8 tubing not the transmission and fuel tubing. (Transmission and fuel tubing collapse in high vacuum)
The only problem the aluminum water bottle produced a hissing sound( not a leak but a high velocity air sound)
Old Mar 1, 2014 | 05:30 PM
Luigi Martini's Avatar
http://www.saikoumichi.com/OCC_page.htm. Check out the website. He has the CAD drawing on the website along with how its constructed. Its not just a can made to hold oil. Its legit and was made for blow by for much higher performing cars. Unfortunately this company wasn't around when the first pioneers started installing these on our cars.
Old Mar 3, 2014 | 06:13 PM
Chris Gregg's Avatar
Get Off My Lawn
I did one out of PVC tube. Thick stuff. No cracking. Couldn't find a catch can at the time that had the size in/out I needed. On my turbo, I ran a vacuum pump to vent the crank case, used big hoses.
Sealed the bottom with pipe glue. Used a standard rubber PVC cap on top, easy to remove to inspect and drain. One outlet just glued straight in. Inlet pipe went in but had a 90 degree elbow glued and aimed down so oil pulled in would be forced down to the bottom and not on through the "can."
Old Mar 3, 2014 | 06:31 PM
03VQMAX's Avatar
This one is my temp one for now, I really don't want one of those fancy ones
Fittings are on, just waiting to change my plugs.
Old Mar 3, 2014 | 08:22 PM
Get Off My Lawn
Wow. Mine would have to be emptied twice a week if I used something that small. That's in using it on the left/front valve cover. Yup, should probably do a compression test next time I'm messing around the bay.
A test I did on Maine was to just put a couple breather filters on the valve covers. Both oil saturated in roughly a months time. One on front valve cover was dripping oil. I could also smell the oil. Definately going for TWO catch cans myself.
Old Mar 4, 2014 | 07:18 AM
colt149's Avatar
PCV oil Catcher
I will replaced mine with this
Amazon.com: ADD W1 Polsih Baffled Universal Aluminum Oil Catch Tank Can Reservoir Tank Polish Ver.1: Automotive Amazon.com: ADD W1 Polsih Baffled Universal Aluminum Oil Catch Tank Can Reservoir Tank Polish Ver.1: Automotive
Stay away from oil catcher with breather:
I got this from Nico club
If venting the valve cover either through a breather filter or catch can with breather filter(s), the factory PCV valve and intake port must be blocked off preventing those sources from sucking in unmetered air. (read: vacuum leak)
Old Mar 4, 2014 | 07:39 AM
Maverick4189's Avatar
made my own, worked great for years now.
Old Mar 4, 2014 | 06:29 PM
Get Off My Lawn
Aw, I like that!!
Old Mar 5, 2014 | 09:50 AM
NmexMAX's Avatar
dot dot dot ...
http://www.infinitifx.org/15-vq35de-...separator.html
http://www.infinitiscene.com/forum/t...-oil-catch-can
Old Mar 5, 2014 | 10:50 AM
maxprivate's Avatar
Black Lion
Really good info.. thank you for the link..so I'm blowing out a lot of white smoke from my front valve cover where I have my breather.. if I ran that to a catch can the out side of the can would go back into the manifold?
I'm thinking I can Tee it into the hose off of the PCV valve ( short hose off the PCV going back into the manifold) since the PCV is a check valve anyway .. am I right? Or would that still be considered unmetered air and it needs to go before MAF so it metered air??
I don't really want to drill out the PCV I rather keep that function as it.. but definitely need to add a catch can. Just not sure of the most effective way to have the car running optimally.
Old Mar 5, 2014 | 10:54 AM
NmexMAX's Avatar
dot dot dot ...
Quite a few different set-ups there.
Old Mar 5, 2014 | 11:49 AM
maxprivate's Avatar
Black Lion
Right ,but those diagrams aren't for a 4th gen so its a bit confusing and doesn't answer my question about the metered air.
I just want to know If teeing both rear ( keeping PCV as is) and front Crankcase sources into Oil catch can IN and then back into Manifold will have the system operating correctly.. already the rear is unmetered air anyway isn't it? So Only the front valve cover was metered I believe by the MAF.
Old Mar 5, 2014 | 01:01 PM
NmexMAX's Avatar
dot dot dot ...
Same concept for a 4g. Identical. And yes, front is metered, but if DC'd, the front VC will then suck more air into the combustion chambers, and not be metered by the MAF. Hence modification of the rear PCV is needed to balance that.
Old Mar 5, 2014 | 01:11 PM
maxprivate's Avatar
Black Lion
Hhmmm my front is actually releasing a white smoke with oil mist now .. not pulling air in.
So should I choose a Catch can with 2 INputs so that I can then bring the front VC and tube off the PCV valve ( rear cover) to the oil CC then back into the manifold? But this would still be unmetered air cause is dumping back into the manifold anyway.
But that's why tuning comes into play I guess.. I'm running emanage Ultimate now with my SC and I need a fine tune anyway.
Old Mar 5, 2014 | 01:58 PM
NmexMAX's Avatar
dot dot dot ...
FMFS, SC. Damnit.
That changes things IMO. I was wondering about the white smoke. I would delte it, and vent both VC's. There are plenty o PCV threads in the SC/Boosted forum from what I remember.
Here's one I remember.
http://forums.maxima.org/8281111-post8.html
Old Mar 5, 2014 | 04:55 PM
maxprivate's Avatar
Black Lion
FMFS, SC. Damnit.
Thanks.. I will read up on it.
litch
123
Jan 4, 2024 07:01 PM
Miket2006
Mar 1, 2021 03:55 AM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
