torque pressure sensor
Old Mar 12, 2014 | 11:38 AM
Scott LaRock's Avatar
Throttle position sensor
Car idling low, was told it's the torque pressure sensor, where is it located on my car? thanks....
Old Mar 12, 2014 | 11:48 AM
NmexMAX's Avatar
dot dot dot ...
Any more elaborations on who told you this?
Old Mar 12, 2014 | 01:58 PM
New mechanic I got for my car..
Maybe I got the part wrong... I will confirm. Usually it's something located on the pedal but our cars are different.
Old Mar 12, 2014 | 02:06 PM
NmexMAX's Avatar
dot dot dot ...
Did he pull the code, or verify it, voltage check? What year is your car?
Old Mar 17, 2014 | 09:28 AM
2002, pulled a 220 code, will check when I get home.
I need new dashlight display lights for my car, can I pick them up at pepboys or autozone?
Old Mar 17, 2014 | 12:39 PM
DjHackStyle's Avatar
U prolly need a new throttle body or pedal id bet the throtle body though, that controls the idle in ur 2002
Old Mar 17, 2014 | 01:31 PM
Well, it's located on the throttle body so I'd have to buy the whole part anyways. I might as well, I'll pull the code once I get back home but most likely.
Also the clutch sticks to the floor lol, I think it has a air leak.
I'm getting a price of 600 bucks for it, I just need the throttle body, someone post a link from a good website to buy from? and do I need oem or aftermarket?
Old Mar 18, 2014 | 08:28 AM
NmexMAX's Avatar
dot dot dot ...
You can get used, or get NWP's. Depends on what you want.
www.car-part.com
www.nwpengineering.com
www.courtesyparts.com
www.rockauto.com
www.thepartsbin.com
Old Mar 18, 2014 | 09:51 AM
I thought it was included in the throttle body but it seems to be sold seperate.
http://www.partstrain.com/store/??N=...universal:0%29
I'm getting 420 and 430 codes...
Old Mar 18, 2014 | 11:23 AM
NmexMAX's Avatar
dot dot dot ...
Ahh, so that has nothing to do with the TB though. Pre-cat code.
Old Mar 19, 2014 | 08:13 AM
I need a new cat, I was thinking of removing the cat and adding a resignator, what's the cheapest method at doing this while keeping the noise down to a minimum without the cat?
Old Mar 19, 2014 | 08:20 AM
NmexMAX's Avatar
dot dot dot ...
Ok, 420 and 430. Those are pre cats. Not the main cat. Our cars dont even know if/when they have a main cat.
Resoantor wont do you any good.
Old Mar 19, 2014 | 10:18 AM
DennisMik's Avatar
$16 cheaper here:
http://www.courtesyparts.com/22620-t...ml?cPath=1956&
Old Mar 21, 2014 | 09:33 AM
But the car idles low, my mechanic says to get a new throttle body, what's I'd like to know is if the throttle body is bad, would that show up as a code in the ecu?
Thanks, I'm debating buying only the switch vs the refurbished tb and swith? Isn't it possible to just clean the throttle body without having to change it?
Also, I want to get rid of the cat, it's factory and never been changed, what's the cheapest way to do this while limiting the noise? My mechanic says take it to a muffler shop, remove it and install a resognator but someone on here told me that's a bad idea.
Test pipe?
Old Mar 21, 2014 | 12:05 PM
NmexMAX's Avatar
dot dot dot ...
If your car is an 2002, then yes, the TPS/APPS will definitely throw you a code. And it would go into limp mode of the voltages aren't within a certain range of each other and you wont be able to break 5 MPH.
Also, not sure why you want to do the test pipe. I've seen cats las a long time. It' more so your pre-cats that will cause problems.
What's your car idling at now?
Old Mar 22, 2014 | 01:56 PM
Under 1, it also stutters slightly. What's the official name for the pre cats on the MA in a? I'm gonna order them and the throttle body.
Old Mar 24, 2014 | 10:01 AM
I just order the TPS and know I'm looking for the precats...
Old Mar 24, 2014 | 12:16 PM
njmaxseltd's Avatar
Under the 1 on the tach is just under 1,000 RPM's.
It should idle at around 700, is that where it's at?
I'd be looking at the stutter (misfire?) before you change anything idle related.
Old Mar 24, 2014 | 12:18 PM
How do I address the misfire? Check the ignition coils? I bought the TPS already, it's on the way soon.
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
gustavison
Oct 4, 2015 06:50 PM
JoshG
51
Sep 21, 2015 10:41 PM
RWCreative
Sep 21, 2015 11:01 AM
bumpypickle
Sep 20, 2015 08:22 AM
