P0300 & Emissions not ready but car runs perfect, why?
Old Mar 25, 2014 | 07:00 AM
DjHackStyle's Avatar
I recently replaced the throttle body and that fixed a small problem i had. But since i bought the car every few months i get a p0300 code and then it goes away by itself and recently it came back and now its always pending so it comes and goes. But car runs perfect idles great and never misfires, whats the problem?
Recently changed intake manifold gasket and elbow gasket and throttle body gasket and newer throttle body.
Since i had to reset the ECU to perform the idle relearn i also noticed my readiness monitors for catalyst and o2 sensor are still "incomplete" or "not ready", Its been 250 miles since i did ECU reset, why are they still not ready?
*EDIT* the car just set readiness, it took about 250 miles and 8 days, no explanation it just did.
Car runs perfect, i dunno if i should do anything.
Old Mar 25, 2014 | 07:27 AM
george__'s Avatar
Faulty spark plugs or wires
Faulty coil (pack)
Faulty oxygen sensor(s)
Faulty fuel injector(s)
Burned exhaust valve
Faulty catalytic converter(s)
Stuck/blocked/leaking EGR valve / passages
Faulty camshaft position sensor
Old Mar 25, 2014 | 07:55 AM
Faulty coil (pack)
Lolz i cant throw all these parts at the car wtf thaz crazy.
Spark plugs - replaced them oem ngk
Coil packs - mayb theyre old and oem
O2 sensor - dont know, my fuel trims are nice and good
Injectors - mayb theyre oem and could be a lil clogged i guess?
Burned exhaust valve - no idea
Catalytic converter - no idea, i did gut the rear precat, no clogged symptoms.
Egr valve passages - i think 03 maximas dont have egr?? Not sure though
Camshaft sensor - wouldnt i have problems starting? No symptoms
Old Mar 25, 2014 | 08:05 AM
george__'s Avatar
Maybe... Depends on how you loook at it
If you do replace the coil packs... GO OEM!
Old Mar 25, 2014 | 09:08 AM
The_Fixer's Avatar
DO NOT LISTEN TO George_ I bet you have a aftermarket coil pack in there! its one of the issues with using non oem.
Old Mar 25, 2014 | 12:38 PM
A miracle just happened my car set readiness it took 8 days everything is ready, cant believe it took so long but that worked out.
Ok ill look at all the coils and see which one looks different
Old Mar 25, 2014 | 10:10 PM
george__'s Avatar
That's what I told him...
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Balkins
Aug 12, 2015 06:39 AM
acw
Aug 7, 2015 04:20 PM
yat70458
Aug 3, 2015 01:16 PM
