trans speed sencor
Old Mar 27, 2014 | 05:45 PM
interceptor429's Avatar
trans speed sencor
i replaced the tss and now speedo and miles don't work and wants to heat up after about 20 mins ....it didn't do this before just had erratic idle and high rpm shifts ...any thoughts ?
Old Mar 27, 2014 | 06:26 PM
Itz Shak's Avatar
Can't wait to hear replies because my speedometer isn't working either..
Old Mar 27, 2014 | 06:36 PM
maximasicilian123's Avatar
Search u idiots what is wrong with you don't you know how to search? There's a million threads on this just pick one and start guessing. This is not the kind of forum where we actually guide you to diagnose or help u figure out what aftermarket parts are proven to work. God :Jesus: lord : hash tag losers. Page 44 paragraph 88 line 32
Old Mar 27, 2014 | 06:41 PM
lol
some onec must have shown you wrong ,we are to help each other ,and not to ******** likes you didn't you get the post-it wise cracker/
Old Mar 27, 2014 | 06:42 PM
litch's Avatar
your mom is gonna be pissed when she finds out what you did to her dryer.
B*tch.
Old Mar 27, 2014 | 06:47 PM
Yea ok..keep thinking someone is gonna tell u the problem. Ur gonna change a hundred things and spend 2months on here before u find the problem. Go to a mechanic next time u get a oil change and ask them. Or waste your time on here. Look at how many views u have and how many answers are actually gonna do u any good
Old Mar 27, 2014 | 07:36 PM
Itz Shak's Avatar
Maybe I was hoping to hear about someone who had the same problem I had so I could get a better clue where to look.
Old Mar 27, 2014 | 07:55 PM
Try automotive. Com forum. It takes a while but the ones who answer are mechanics theyl help you for sure
Old Mar 27, 2014 | 08:13 PM
NmexMAX's Avatar
dot dot dot ...
I'll allow it for now but consider this your last warning.
Old Mar 27, 2014 | 08:52 PM
Nealoc187's Avatar
SLOW
try to relax man.
Old Mar 28, 2014 | 08:45 AM
The_Fixer's Avatar
Please explain more!
What heats up?
Erratic idle give example when it happens?
High rpm shift please tell what gear this
is happening in?
What exactly happened that made you replace the tss?
And above all scan for any trouble codes and post them/search.
Old Mar 28, 2014 | 12:39 PM
the cars radiator heat gauge gets to almost red area,the speedo stopped and mile reader stopped,after i changed the speed sensor,all was working fine before ...the reason i changed it was 1-2 not shifting and very high RPM and no speed gain and the idle was up and down and would not idle well ...after replacement it idles great and shifts perfect now ,but these other problems started,....i searched and found the cause to the tss issue ,but can not find these.HELP thanks mr. The_Fixer.
What heats up?
is happening in?
Old Mar 28, 2014 | 01:22 PM
The_Fixer's Avatar
Ok what year is your car? It sounds like you are having either a cluster issue or ecu issue.does the car actually overheat?
Old Mar 28, 2014 | 01:37 PM
sorry its a 2000 and no it gets close but not quite ,...it wasn't doing these before i changed the speed sensor...i'm puzzled and codes are PO 500 ,PO720 TSS I REPLACED, PO733 TRANS PROBLEM, and PO505 IACV .FIXED with tss replacement
Old Mar 28, 2014 | 03:27 PM
nestorlugo's Avatar
DTCP0500VEHICLESPEEDSENSOR(VSS)
DiagnosticProcedure DiagnosticProcedure NFEC0801
1CHECKVEHICLESPEEDSENSORINPUTSIGNALCIRCUITFOROPENA NDSHORT
1.Turnignitionswitch“OFF”. 2.DisconnectECMharnessconnectorandcombinationmeter harnessconnector. 3.CheckharnesscontinuitybetweenECMterminal86andcom binationmeterterminal32.
RefertoWiringDiagram.
Continuityshouldexist. 4.Alsocheckharnessforshorttogroundandshorttopower.
OK © GOTO3. NG © GOTO2.
2DETECTMALFUNCTIONINGPART
Checkthefollowing.
+ HarnessconnectorsM46,F44
OKorNG
+ HarnessforopenorshortbetweenECMandcombinationmeter
© Repairopencircuitorshorttogroundorshorttopowerinha rnessorconnectors.
3CHECKSPEEDOMETERFUNCTION Makesurethatspeedometerfunctionsproperly.
OK © GOTO5. NG © GOTO4.
OKorNG
4CHECKSPEEDOMETERCIRCUITFOROPENANDSHORT
Checkthefollowing.
+ HarnessconnectorsM15,E81
+ HarnessforopenorshortbetweencombinationmeterandABS actuatorandelectricunit
OKorNG
OK © CheckcombinationmeterandABSactuatorandelectricunit r.RefertoELorBRsection. NG © Repairopencircuitorshorttogroundorshorttopowerinha rnessorconnectors.
5CHECKINTERMITTENTINCIDENT Referto“TROUBLEDIAGNOSISFORINTERMITTENTINCIDENT”,E C-126.
© INSPECTIONEND.
Old Mar 28, 2014 | 10:02 PM
Checkthefollowing.
OKorNG
OKorNG
Checkthefollowing.
OKorNG
© INSPECTIONEND.
ok this all lost me ,sorry i'm new to this car and this language .
Old Mar 28, 2014 | 10:47 PM
Itz Shak's Avatar
Thanks mate
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
knight_yyz
Nov 1, 2015 01:34 PM
ef9
Oct 4, 2015 08:43 AM
