Fuel pump problem please help
Old Apr 4, 2014 | 04:50 AM
ashort's Avatar
last night i replaced my fuel pump in my 03 maxima, and it started right up after turning the key to accesories to let the pump build up some pressure. i drove it around the block and it seemed fine, if not drove better. but this morning, i went to start it and it cranks and cranks and turns over maybe 1 out of 5 attempts and wen it does it will idle for thirty seconds then bog out. i got no clue what to do now that the new pump and filter are in
Old Apr 4, 2014 | 06:47 AM
DennisMik's Avatar
Why did you replace the fuel pump? Was it for the same problem?
It is possible that the fuel pressure regulator is bad.
Then the usual question - is the check engine light on?
Old Apr 4, 2014 | 09:11 AM
ashort's Avatar
i changed it because the engine bogged out, it would crank all day but wouldnt turn over, listened for the pump when i turned the key and heard nothing. i think it was a spark plug, possibly flooded it because i put in new plugs and it fired up
Old Apr 4, 2014 | 09:32 AM
Maxima 97 SE's Avatar
what brand is the pump. On Nissans the only pumps that will work and actually hold pressure is oem Unisia jecs pumps which are Nissan fuel pumps. Airtex is the worst brand to buy and it wont hold fuel pressure.
BkGreen97
Apr 2, 2016 05:47 AM
RWCreative
Sep 21, 2015 11:01 AM
rnb754
Sep 14, 2015 11:39 PM
conansriver
Sep 11, 2015 10:26 AM
