AE skirts on SE
Old Apr 11, 2014 | 08:56 PM
King_Ten_Ahead's Avatar
AE skirts on SE
Recently picked up some side skirts thanks to a fellow org member!
Now..obviously I dont have the holes in the side for the tabs on the skirts and id like to avoid making holes if possible in the rockers because I want to avoid rust. the 3m tape I have didnt really wanna stick unfortunately. I had the idea to use the rubber butyl (something like that) that I have left over from a tail light swap to hold the topside to the body so it sits flush and doesnt fall off! Any thoughts on this? Plausible idea or should I consider other routes. TIA!
Old Apr 12, 2014 | 07:19 AM
alanfury's Avatar
Velcro tape. Just kidding. How about epoxy?
Old Apr 12, 2014 | 08:19 AM
The_Fixer's Avatar
http://solutions.3m.com/wps/portal/3...alog/?MDR=true
Old Apr 12, 2014 | 08:30 AM
Ive never worked with epoxy..Ill have to look into it
3m tape didnt wanna stick..
Old Apr 12, 2014 | 08:38 AM
The_Fixer's Avatar
Dont use the foam type there is a gray one and use the promoter
When i replaced my 5.5 se side skirt from the dealer it came with 2 screws and 5 1" squares of 3m brand sticky tape it was gray.they have never came off and dont wiggle.
Old Apr 13, 2014 | 08:25 AM
Mine is white so I guess I dont have the right stuff. I went hunting at every store in town and thats the only stuff I could find. Looks like ill be ordering some soon. Thanks!
Old Apr 13, 2014 | 11:08 AM
DOODOOCHIP's Avatar
I used different brands of 3m tape and not all work the same. The white one was good for like a week. The gray one has been holding the window spoiler for two year now.
Old Apr 13, 2014 | 02:54 PM
Awesome. Thank you. I too have the white stuff and had issues mounting my rear lip
Old Apr 13, 2014 | 03:18 PM
02pearlmax's Avatar
Like others have said, the gray 3M tape with the red backing is the stuff you want as it is much stronger than the white tape. Also, in my experience, 3M tape is harder to apply in humid weather, so it might help if you do it on a dry day with low humidity.
Old Apr 13, 2014 | 03:41 PM
Thanks for the tip! How much should I use? Run it Long the whole length or..?
Old Apr 13, 2014 | 05:18 PM
The_Fixer's Avatar
More is better get the prep spray or wiped and clean surface real good
Old Apr 14, 2014 | 12:50 PM
Awesome thanks!
Old Apr 14, 2014 | 02:56 PM
george__'s Avatar
More... If there is rust where the side skirt is supposed to go fix it up or get a bodyshop to fix up the rust spots and also clean area is important.
litch
123
Jan 4, 2024 07:01 PM
maxima-junky
Nov 10, 2015 09:12 AM
knight_yyz
Nov 1, 2015 01:34 PM
Jamie Bolus
Sep 14, 2015 11:35 AM
