Mode $06 Data
Old May 5, 2014 | 06:15 PM
mazda626es's Avatar
Mode $06 Data
I've been having issues with my girlfriends car and I wind up buying a ELM scanner. I tried a few applications on my computer, but I couldn't get any to work. So I bought an app for 5 bucks on Android called Torque. After running the test, I got a failed on this line:
TID:$07 CID:$03
- Minimum sensor Voltage for test cycle(calculated)
Max: 31
Test result value: 44
FAIL
Everything else passed. How can I tell which component failed? I tried the search features on this site, and I also tried looking through google but I can't seem to find the Mode $06 data anywhere. Does anyone have a list, or know where I can get it.
I also had a error code in the computer P1456, but I'm pretty sure I know what that is.
Oh, and the car is a 2003 Maxima SE Automatic with 127,000 miles.
Old May 5, 2014 | 06:32 PM
alanfury75's Avatar
I have Torque pro also. I haven't run any tests though. Do you have any fault codes popping up? They also have a forum similar to this that you can pick up some tips and tricks.
Old May 5, 2014 | 08:03 PM
TallTom's Avatar
Try another app called car gauge pro, the free version.
Old May 5, 2014 | 08:41 PM
mazda626es's Avatar
I do, I have a P1456 code popping up. Which would make me think it could be a failure in the vent control valve, but i'd like to check the component ID to see if thats where the failure is. I suppose I could take it out and hook a 9 volt up to it and see if the plunger moves, but I'd like to see If I can get the whole Mode 6 definition sheet to see what the other values are.
Old Dec 16, 2014 | 12:20 PM
maximaguy92's Avatar
any updates to this thread cause I am having the same exact issue
Old Dec 16, 2014 | 03:47 PM
Child_uv_KoRn's Avatar
Bad *** Newb
bull**** emissions
either gas cap is loose/bad, purge valve is bad or crack in a hose/canister
canister and hose junk are behind the rear left tire
purge valve is bolted to IM with the vac lines on it and blue connector
I would guess that there's a crack in the canister or hose back there
BkGreen97
Apr 2, 2016 05:47 AM
gustavison
Oct 4, 2015 06:50 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
pktaske
Sep 4, 2015 08:40 AM
