A/C ambient temp problem
Old Jun 6, 2014 | 03:42 PM
Legacyrisk's Avatar
The ambient temp reads -22 all the time unfortunately that's what my a/c goes by so I'm getting hot air. I've replaced both the front right sensor as well as the control module NO change. I live in the Az. desert please help
Old Jun 6, 2014 | 09:01 PM
DennisMik's Avatar
Assuming the sensor you installed is good (was it new or a junkyard part), the you might want to check the wire harness for cuts or damage. The wire harness runs up into the engine compartment by the coolant overflow tank.
Old Jun 10, 2014 | 03:35 PM
Legacyrisk's Avatar
thanks, wireing good outer sensor my next stop is the interior auto control sensor behind the module
Old Jun 10, 2014 | 05:29 PM
davidrae's Avatar
Same thing happened to me. The default temp on the ambient temp sensor is -22. I replaced my sensor and it works perfect
Old Jun 26, 2014 | 02:46 PM
Legacyrisk's Avatar
Problem solved
I can help with most a/c problems I learned a lot let me know if I can help.
RWCreative
Sep 21, 2015 11:01 AM
pears
Sep 18, 2015 05:25 AM
EdRomo86
Sep 12, 2015 07:49 PM
NissanNismoZ
Sep 12, 2015 07:30 AM
asianstyle
Sep 10, 2015 11:30 AM
