Wobbling/jerking in suspension
Old Jun 10, 2014 | 06:21 AM
Jord61194's Avatar
I have movement in the suspension or wheels even when fully stopped and e- brake is applied.
First I thought it was the motor mounts. Put in poly inserts
Then I thought it was suspension problems. I put in d2 coilovers
My thinking is it could be sway bar bushings or control arm bushings.
Does anyone have any experience with this problem?
Note: I can sit in it and rock it forward and back with e- brake and brakes fully applied and it still wobbles and moves. Even a car wash will make it jerk. Also does it when I transition between each gear.
I will apologize ahead of time if there is a post about this already. But I am unable to find anything remotely close to this. Any opinion is appreciated.
Old Jun 10, 2014 | 01:50 PM
djfrestyl's Avatar
Suspension Yoda
Need more details. Which direction does it move? Any noises? Can you post a video?
Old Jun 10, 2014 | 05:12 PM
Jord61194's Avatar
No noise at all, I mean I have the never ending coilovers pop but that's unrelated. But the movement is forward and backwards approx: 1-2" total. Kinda like a bad joint but that would be impossible since I have all the brakes fully pressed and it still does it.
Old Jun 10, 2014 | 05:13 PM
Jord61194's Avatar
Also: the car is a 2002 se 6mt with 50k miles.
Old Jun 11, 2014 | 07:57 AM
djfrestyl's Avatar
Suspension Yoda
It *sounds* like a very bad control arm bushing or ball joint, but need a video to confirm.
Get under the car while it's on the ground and investigate. Have someone push the car while you poke around. The movement should be visible and very apparent which component is the culprit.
Old Jun 11, 2014 | 01:58 PM
00Lightsout's Avatar
I just replaced mine yesterday... but they usually will make noise when bad. Note: if u buy the MOOG like I did, you'll need to press out the old, hammer the arm hole smaller with a punch and then press in the new joints. My new MOOGs are awesome!
Sounds like the upper trans mount is shot. idk of a Poly insert for that, but I believe someone on here did successfully make poly inserts for both the upper mounts.
The mounts won't make so much noise because of the rubber in them.
Apr 16, 2020 05:15 AM
knight_yyz
Nov 1, 2015 01:34 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
